Connection issue with GL-AR750S-EXT
I have recently moved and am trying to get my GL-AR750S-EXT router, but I have had issues attempting to connect to the router in any way. My laptop will read that it is connected to the router for a few seconds, then think it is not connected to anything. This cycle repeats every 15ish seconds. The laptop is connected via ethernet cable. I have tried multiple cables.
Attempted to reset the router by holding down the reset button, but continue to have the same issue. The router was working perfectly earlier today.
Have you changed the power adapter?
Figured out that the power cable that I was using went bad. Thanks for the advice.
