Hello there,
I have been trying to use the Mudi V2 in a few scenarios and have been facing the following issues:
When data-roaming to China, ShenZhen, the router would often just give "No Internet" error on the screen and be unusable. I will have to power cycle the router and hope it works (60% of the time, it will work for a few minutes, then show good signal with China Mobile and "No Internet" comes up again. The other 40% of the time it will show no signal.). Taking the SIM card out and putting it into my Samsung handphone would work just fine.
When data-roaming to Malaysia, Johor Bahru, the router would give a similar issue as point 1, but unlike in China it will never show no signal as it will show that it is connected to the carrier. Unlike in China, the router will stop working (no WiFi signal) despite being turned on and showing "No Internet" on the screen. Taking the SIM card out and putting it into my Samsung handphone would work just fine.
When using in Singapore, the router appears to work just fine, although it will not switch carriers properly when switching from Malaysia carrier to Singapore carrier, and I have to power cycle the router just to get it to work again.
Is there any advise on what could be done? I have tried this same SIM card in other MiFi routers and it works just fine without any hiccups, and also in my Samsung phone with no issues at all.
