Just bought a new Flint2 yesterday. On setting up the wifi sitting 6 feet away from the router android mobile disconnects whenever a high bandwith session like instagram, titok is started. Wired connections are fine. The wifi is connected with decent RSSI but the ssid states connected without internet. WPA2-PSK, 11ac,an ,ax,80 Mhz, medium Tx power. No apps installed, bog standard settings. I have tried different power, different channels, no auth..wifi analyser does not show anything unexpected.
System log
Wed Jun 5 10:34:22 2024 kern.notice kernel: [69129.583477] 7986@C08L3,hw_ctrl_flow_v2_link_up() 72: wdev_idx=2
Wed Jun 5 10:34:22 2024 kern.notice kernel: [69129.605079] 7986@C08L3,UpdateBeaconHandler() 2067: BCN_UPDATE_INIT, OmacIdx = 0 (rax0)
Wed Jun 5 10:34:22 2024 kern.warn kernel: [69129.612986] 7986@C08L2,bcn_buf_init() 170: BcnPkt is allocated!, bcn offload=1
Wed Jun 5 10:34:22 2024 kern.info kernel: [69129.622615] br-lan: port 6(rax0) entered blocking state
Wed Jun 5 10:34:22 2024 kern.info kernel: [69129.627851] br-lan: port 6(rax0) entered disabled state
Wed Jun 5 10:34:22 2024 kern.info kernel: [69129.633253] device rax0 entered promiscuous mode
Wed Jun 5 10:34:22 2024 kern.info kernel: [69129.637944] br-lan: port 6(rax0) entered blocking state
Wed Jun 5 10:34:22 2024 kern.info kernel: [69129.643166] br-lan: port 6(rax0) entered forwarding state
Wed Jun 5 10:34:22 2024 kern.warn kernel: [69129.652309] 7986@C08L2,mbss_virtual_if_close() 171: ===> rax1
Wed Jun 5 10:34:22 2024 kern.warn kernel: [69129.658150] 7986@C01L2,RTMP_COM_IoctlHandle() 1505: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DOWN
Wed Jun 5 10:34:22 2024 kern.warn kernel: [69129.666540] WiFi@C08L2,ap_link_down() 7219: (caller:wdev_do_linkdown+0x20/0x38 [mt_wifi]), wdev(3)
Wed Jun 5 10:34:22 2024 kern.err kernel: [69129.675743] 7986@C08L1,UpdateBeaconHandler() 2047: wdev(3) bss not ready (state:2, caller:ap_link_down+0x98/0x238 [mt_wifi])!!
Wed Jun 5 10:34:22 2024 kern.notice kernel: [69129.687134] 7986@C01L3,wifi_sys_linkdown() 1364: wdev idx = 3
Wed Jun 5 10:34:22 2024 kern.notice kernel: [69129.693060] 7986@C08L3,hw_ctrl_flow_v2_link_down() 123: wdev_idx=3
Wed Jun 5 10:34:22 2024 kern.notice kernel: [69129.702356] WiFi@C01L3,wifi_sys_close() 945: wdev idx = 3
Wed Jun 5 10:34:22 2024 kern.notice kernel: [69129.707929] 7986@C08L3,hw_ctrl_flow_v2_close() 41: wdev_idx=3
Wed Jun 5 10:34:22 2024 kern.warn kernel: [69129.713814] 7986@C01L2,RTMP_COM_IoctlHandle() 1528: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DEINIT
Wed Jun 5 10:34:22 2024 kern.info kernel: [69129.722071] extif_put_dev(rax1)
Wed Jun 5 10:34:22 2024 kern.info kernel: [69129.725205] mtk_ppe_dev_unregister_hook : ineterface rax1 set null (2)
Kernel log
69129.351585] 7986@C13L2,Set_DisConnectAllSta_Proc() 22864: Send DeAuth (Reason=2) to 4e:9c:78:46:40:64
[69129.366054] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
[69129.373531] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
[69129.380608] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:4e:9c:78:46:40:64
[69129.388085] 7986@C08L3,ap_mlme_deauth_req_action() 248: ---> wcid = 32767
[69129.395070] 7986@C15L2,APPMFInit() 133: [PMF] apidx=2, MFPC=0, MFPR=0, SHA256=0
[69129.402450] 7986@C01L3,wifi_sys_linkdown() 1364: wdev idx = 2
[69129.408343] 7986@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (94:83:c4:a3:6d:e0), Reason 0x10
[69129.417210] 7986@C03L1,ExtEventBeaconLostHandler() 176: AP Beacon OFF!!!
[69129.424308] 7986@C08L3,hw_ctrl_flow_v2_link_down() 123: wdev_idx=2
[69129.432808] WiFi@C01L3,wifi_sys_close() 945: wdev idx = 2
[69129.438416] 7986@C08L3,hw_ctrl_flow_v2_close() 41: wdev_idx=2
[69129.444302] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 2
[69129.449799] 7986@C18L3,BuildChannelList() 507:
[69129.454354] 7986@C23L3,operate_loader_phy() 360: oper_cfg: prim_ch(36), ht_bw(1), extcha(1), vht_bw(1), cen_ch_2(0), PhyMode=177!
[69129.466026] 7986@C23L3,operate_loader_phy() 374: oper_dev after adjust: bw(2), prim_ch(36), cen_ch_1(42), cen_ch_2(0),ext_cha(1)!
[69129.477678] 7986@C23L3,operate_loader_phy() 393: oper_dev after decision: bw(2), prim_ch(36), cen_ch_1(42), cen_ch_2(0)!
[69129.488708] WiFi@C00L2,dump_ht_cap() 29: Caller: wlan_operate_init+0xa4/0x148 [mt_wifi]
[69129.496707] wdev_attr_update(): wdevId2 = 94:83:c4:a3:6d:e0
[69129.502291] WiFi@C12L1,wifi_sys_open() 907: wifi_sys_open():band1 group_idx[2]=4, bw_grp=16 omac=0
[69129.511246] 7986@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=2
[69129.518079] 7986@C01L3,wifi_sys_linkup() 1231: wdev idx = 2
[69129.569126] 7986@C00L3,wtc_acquire_groupkey_wcid() 84: Found a non-occupied wtbl_idx:543 for WDEV_TYPE:1
[69129.569126] LinkToOmacIdx = 0, LinkToWdevType = 1
[74464.252489] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Wed Jun 5 10:34:22 2024 daemon.notice netifd: Wireless device 'mt798612' is now up
