Is it possible to control the power pin of the MT-300N-V2 (or other routers) from software? I power a device from the 3.3VD and GND Pins and need to reset it by cycling the power.
Thanks for any workable approach.
Sorry that cannot be done.
But you can control the power of the USB port. So if you have an USB powered device it will work.
