Controlling ATX Board without Comet PoE?
Hey there, I was wondering if it’s possible to use the ATX board with devices other than the explicitly supported GL-RM1PE.
I see the ATX Board has a USB cable to connect to the Comet, are there known specifications around its messaging protocol and could it be controlled by a device such as a Raspberry Pi or a GL.iNet router instead of the full Comet KVM?
For example, I already own other GL.iNet devices including the Flint 3 Router which is placed directly next to my PC anyway. I’m wondering if it could be possible to connect the ATX Board to its USB port and control it through a custom extension or ssh commands (assuming simple support isn’t built in natively)
All I’m looking for is the ability to either press a button in the web UI/LuCI or send an ssh command to do things like power on/off the PC or force/hard reboot. It doesn’t need to be pretty and I don’t need full KVM functions as the PC runs its own remote access software, I just want to be able to remotely force a reset in case it’s frozen up.
Has anyone done something like this before? or anyone with the ATX Board able to test it out?
This doesn't really answer the question, but it looks like it's just a USB device and atxpower is just a bash script to the device so it should be feasible depending on your technical skills:
