Please take a look at the following scenario. I have connected my GL.iNet GL-MT3000 (Beryl AX) to two internet sources - Ethernet and Android 4G data tethering via USB. I have set up Tethering as the highest priority. I was trying to test what would happen in case I shut down Android tethering and how long it would take to restore the connection using the backup Ethernet connection.
I was quite impressed to see that I could do it even during a video call - the call would freeze for 3-4 seconds but the connection would be restored using a backup source. However, when I re-connected the Android tethering connection, I noticed that I’d still be on the Ethernet, even though Tethering was online again. If I wanted to come back on Tethering, I’d need to disable tethering manually by unplugging the cable. Therefore I have 2 questions regarding how to use the Admin Panel:
Is it possible to clearly view where exactly is the traffic coming from/to? Currently, the only way I could test it is by monitoring my Android device’s traffic whilst tethering, which is not very efficient. It seems like there isn’t a way how can I view where am currently connected to.
Is it possible to manually switch the source using Admin Panel? So far the only way I could do it is by physically terminating the connection of the secondary source, to switch to the primary one.
I did try enabling this Forcer Refresh Streams option, but it didn’t seem to have made any difference.
Can you advise me please how can I achieve more control over what source of internet connection am I using? If it’s impossible, may I request it as a new feature?
