Hello I have both GL-AR300M and GL-AR750 they both are great mini travel router.
Currently my existing devices:
internet > fiber modem (192.168.1.1) > wireless router (pppoe with VLAN 500, dhcp, 192.168.43.1) > access point (192.168.43.2)
My existing wireless router or access point have issue with DHCP they are limited to 2 days lease time and they unable to handle to busy renewal ip address, either one of them if I enable it will hang. Perhaps due to many smarthome devices (IoT, IP cameras).
So I wanted to use the one of GL-iNet, either GL-AR300M or GL-AR750 to convert as DHCP server and connect it eithe in my wireless router or access point, within same subnet and serve with following and issue the device with information:
Disable DHCP on your wireless router and set its Static IP to 192.168.43.1. Set access point Static IP to 192.168.43.2.
Configure your GL.iNet device in Router network mode with Static IP 192.168,43,3 and DCHP range 192.168.43.100-192.168.43.199 (for up to 100 IP’s) using MORE SETTNGS → LAN IP. Connect one LAN port to your wireless router, but do NOT connect the WAN side to anything (no wifi, no cable, no tethering, no 3G/4G modem).
If you want to manually set the lease time, you can use LuCI → Network → Interfaces → Edit LAN → DHCP Server.
I did this the devices connected it will given the IP address as follow:
Gateway: 192.168.43.3 to the GL.iNet not to my wireless router 192.168.43.1.
That’s way I puzzed no choice to use the GL.iNet as NAT to issue the IP addrress, Gateway and DNS1, DNS2. I can not find the DHCP GL.iNet with DHCP server configuration specificly for the pointed gateway.
The sample there showing "6,192.168.2.1,192.168.2.2 " what “6” means? and yours what is “3” mean? How can I do more understand on this DHCP-Options settings?
At this point I decided to set my GL.iNet to “192.168.43.5”.
It seem these configuration is working. But I would like to know more understand where to configure DHCP-Option above, I been looking at https://linux.die.net/man/8/dnsmasq. I still puzzed.
I would to know how to set the DHCP reservation with “permanent” lease time given from GL.iNet? Is it “infinite”?
Like this sample DHCP Server with DHCP reservation permanent lease time from my wireless router:
There are few places I found related to DHCP, but I still no idea what is the correlation within outside and inside from luci.
The following URL has description of DHCP, including all the DHCP options:
If you use the GL-AR750S as the default gateway, then I think all external traffic will have to hit that device first, instead of going directly to your wireless router.
You can use Static IPs, or set DHCP Lease time to 100000h (which is >10 years) or even higher.
Both the GL.iNet UI and the LuCI UI are really front-ends to the OpenWrt commands and API, so both should show the same settings. GL.iNet developed their UI to be much friendlier and simpler to use for the majority of owners, vs the much more detailed and complicated LuCI UI developed by the OpenWrt/LEDE project. I use the GL.iNet UI for basic functions and only use the LuCI UI if not available.
Thanks, but “infinite” will assign as permanent.
I tried to register about 140 IP addresses and trying to registering them into “Static IP Address Binding” in luci (Network > DHCP and DNS > Static Leases) based on my specific IP ranges and categories, but it seem the devices stop issuing IP address and devices can’t get any IP address, in my “cmd” it said “unable to contact your DHCP server. Request has timed out”. I’m not sure if I registered them to many or something else.
