I have two Convexa-B routers with MESH enabled (Main Node and Sub Node 1).
When I connect the OpenVPN Client, the VPN Policy that I have configured appears to be totally ignored. This results in the traffic for all clients which are connected to the MESH main wifi being routed over the VPN.
The firmware version installed on both routers is: 3.215
I checked by running the command ‘ifconfig tun0’ on main router, you can have a look at it to confirm.
On the other hand, could you paste some screenshot or config file to analyze the problem?
