I was planning to use a GL-AR150 as a hotspot controller at a friend’s cafe.
Is the CoovaChilli package available?
Has anyone tested CoovaChilli on it?
Has anyone used a GL-AR150 with Hotspotsystems.com?
Thanks
Paul
Thanks
Paul
Coovachilli package is available in our repo, you can install it.
Some of our client have tested it and works fine.
Thanks for quick reply.
Have just ordered from Amazon.
Will update this to let you know that it works with HotspotSystems soon.
Hey proddick, Did you manage to set up captive portal successfully?
