Cox Wifi Hotspot and Auto reboot router
I'm using a BerylAX and it almost seems like its daily were I lose Internet connection on Cox's open Wifi hotspot. The quick fix got this is to restart the beryl router and the Internet connection comes right back majority of the time without having to go through the captive portal but every now and again I do have to re login to the captive portal. Is there an easy fix for this or maybe though script or a plugin to fix the problem or to auto restart when connection is lost? I already have the beryl to auto restart every morning at 3:00 am and that seems to help some. I need this because of Cox's data cap and I stream everything and if you connect to their wifi hotspot there is no data cap. Any help would be appreciated.
The question seems to be similar, merged into:
