Create Guest VLAN to Internet only on Bume 3
Before I try and break my Brume 3 again having to press the reset button, I thought I would save some time and ask here.
My network configuration:
ISP Modem <=> Brume 3 <=> Brocade ICX managed 24 port switch <=> multiple APs
VLANs have been configured upstream of the Burme 3 on the APs
  • VLAN 1 - untagged
  • VLAN 10 - tagged
I need to connect the switch to a port on the Brume 3 and have VLAN 10 locked-down, Internet access only and VLAN 1 to have full access.
If someone would walk it though using LuCi, it would be greatly appreciated.
There is a bug with the Brume 3 so untagged VLANs break if you add a tagged vlan. This is currently still unresolved.
See this quite long thread here
If you have a vlan capable switch, the workaround would be to use two tagged vlans and separate out untagged ports on the switch and not use untagged on the Brume 3.
That should work. I will explore taking that approach.
Thank you.
