I’m under the impression I can use the GL-AR300M to create an off-grid network within my van to connect a android cell phone or Amazon Fire HD with downloaded movies to display on a flat screen TV with Amazon Firestick TV. I’d be using it like this in areas without WiFi or cell service. At this time I really don’t need it for anything else like for use with public hotspots.
I’d like to be able to power up and have a visible network to connect my devices. How would I do this?
Sorry, I didn’t understand what you meant.
The router will not shut down or disable Wi-Fi due to no Internet connection. You just need to plug it in and connect your client to the router’s Wi-Fi. Are you having any problems using it?
You can access it with your browser. Please note that setting up a network reset will require you to reconnect to WiFi.
If you are using a mobile phone, you can also try our App.
