I previously asked this in the OpenWRT forum and they sent me here: Creating a VLAN for IOT Wifi with a single router - Installing and Using OpenWrt - OpenWrt Forum
I don't know why this is causing me so much trouble. It seems straightforward, but here we are. I'm going to try to describe what I did and highlight areas in bold where I think I may have made a mistake or have a misunderstanding. I've been at this for several hours, so I'm hoping someone can help.
Setup
Here is my setup. I have a GL-MT6000 (flint2) router that shipped with the gl-inet OpenWRT variant. The WAN ethernet-port is connected directly to the modem. The other LAN ethernet ports are connected to various devices including unmanaged switches which are effectively just increasing the number of ethernet ports on the router. I have a main WIFI SSID already setup for 2G and 5G that connect devices in the LAN. I want all of this to remain the same. I also have the guest WIFI setup for guests.
Based on my understanding, my network topology looks roughly like this:
╙── modem
└─╼ flint2-router-wan
└─╼ flint2-router
├─╼ flint2-router-lan2
│ └─╼ unmanaged-switch-1
│ ├─╼ device2
│ ├─╼ device3
│ └─╼ device4
├─╼ flint2-router-lan3
│ └─╼ unmanaged-switch-2
│ ├─╼ device5
│ └─╼ device6
├─╼ flint2-router-lan4
│ └─╼ device1
├─╼ flint2-router-lan5
└─╼ flint2-router-wifi-ssid1
├─╼ device7
├─╼ device8
└─╼ device9
Goal
The new thing I want to do is create a separate SSID that IOT devices can talk to the internet and also talk to each other. This means I can't use the guest network out of the box because it seems to disable devices from communicating within the network and instead just gives them access to the WAN.
From what I understand the way you do this is with a VLAN. My understanding is each new VLAN will require a: device, an interface, firewall rules, and an finally an Wireless SSID.
Steps Taken
I attempted to set this up in LUCI.
Step 1:
I went to Network > Interfaces and then clicked the devices tab. From there I clicked "Add Device Configuration". I changed the following values in the popup:
Device type: VLAN (802.1q)
Base device: 'Ethernet Switch "etho0"'
VLAN ID: 40
Note: this autopopulated
Device name: br-lan.40
I'm unsure about what the base device is doing here. Other options where 'Ethernet Adapter: "acpli0"', 'Wireless Netwowrk Master "HOME-WIFI" (lan)' (which resolved to ra0), the guest wifi which resolved to ra1, 'Ethernet Switch "etho0"', 'Ethernet Adapter: "eth1" (wan)', 'Bridge: "br-lan" (lan)' . I've also seen other tutorials use a VLAN bridge here, and I don't know if I should be doing that.
Then I clicked "Save & Apply"
Step 2:
I went to Network > Interfaces and then "Add new interface...". I changed the following values in the popup:
Protocol: Static address
Device: br-lan.40
Then I clicked "Create Interface".
From there I changed the popup values:
IPv4 address: 192.168.40.1
IPv4 netmask: 255.255.255.0
# In the "DHCP Server" tab, I clicked "setup dhcp server"
I then clicked "Save". Then I clicked "Save & Apply".
Step 3:
I went to Network > Firewall. Under Zones I clicked "Add", and changed the popup values:
Input: reject
Output: accept
Forward: reject
Covered networks: VLAN40
Allow forward to destination zones: wan
Step 4:
I then went to Network > Wireless.
I found the radio device I want to add the SSID to, which was "mt798611 Generic 802.11bgnax Channel: 9 (2.452 GHz) | Bitrate: 573 Mbit/s". In the row for "mt798611" I clicked "Add".
I then changed the popup values:
ESSID: IOT40-WIFI
Network: VLAN40
# In the wireless security tab
Encryption: WPA2-PSK
Key: <the-wifi-password>
Confusion
And here is where I'm stuck. At this point I would expect to see a IOT40-WIFI SSID come up as an available network to connect to, but I don't see anything. The new row in the Wireless Overview table says: disabled - SSID: IOT40-WIFI | Mode: Master, Wireless is not associated. Specifically, this is what I see:
(You'll note I've tried this 3 times with different variants still with no success).
I can ping 192.168.40.1, but I have no idea if I set this up correctly. Clearly I messed something up. I would prefer to learn how to do this via the LUCI GUI first, and then learn how to use the config files.
I've also heard that VLANs are only make sense if you have multiple routers, and I'm not sure if that is true. I do plan to connect another router to act as another WIFI access point in the future to improve connectivity far away from the main router, but it seems like the use-case where you setup a VLAN on the main router for an isolated non-guest wifi network is reasonable. Do I have a misunderstanding?
Additional information from running:
ubus call system board
cat /etc/config/network
cat /etc/config/wireless
cat /etc/config/dhcp
cat /etc/config/firewall
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
OpenWrt 21.02-SNAPSHOT, r15812+1076-46b6ee7ffc
root@GL-MT6000:~# ubus call system board
"kernel": "5.4.238",
"hostname": "GL-MT6000",
"system": "ARMv8 Processor rev 4",
"model": "GL.iNet GL-MT6000",
"board_name": "glinet,gl-mt6000",
"release": {
"distribution": "OpenWrt",
"version": "21.02-SNAPSHOT",
"revision": "r15812+1076-46b6ee7ffc",
"target": "mediatek/mt7986",
"description": "OpenWrt 21.02-SNAPSHOT r15812+1076-46b6ee7ffc"
root@GL-MT6000:~# cat /etc/config/network
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd07:de41:87be::/48'
config device
option name 'br-lan'
option type 'bridge'
list ports 'lan1'
list ports 'lan2'
list ports 'lan3'
list ports 'lan4'
list ports 'lan5'
option macaddr 'MA:CA:D:RE:SS:09'
config device
option name 'lan1'
config device
option name 'lan2'
config device
option name 'lan3'
config device
option name 'lan4'
config device
option name 'lan5'
config interface 'lan'
option device 'br-lan'
option ip6assign '60'
option isolate '0'
option ipaddr '192.168.222.1'
config device
option name 'eth1'
option macaddr 'MA:CA:D:RE:SS:08'
config interface 'wan'
option device 'eth1'
option proto 'dhcp'
option force_link '0'
option ipv6 '0'
option classlessroute '0'
option metric '10'
config interface 'wan6'
option proto 'dhcpv6'
option device '@wan'
option disabled '1'
config interface 'tethering6'
option device '@tethering'
option disabled '1'
config interface 'wwan6'
option device '@wwan'
option disabled '1'
config interface 'guest'
option force_link '1'
option ipaddr '192.168.9.1'
option multicast_querier '1'
option igmp_snooping '0'
option isolate '0'
option bridge_empty '1'
option disabled '0'
config interface 'wwan'
option proto 'dhcp'
option metric '20'
config interface 'secondwan'
option ipv6 '0'
option proto 'dhcp'
option metric '15'
config interface 'secondwan6'
option device '@secondwan'
option disabled '1'
option metric '15'
config interface 'modem_1_1_2_6'
option disabled '1'
option device '@modem_1_1_2'
config rule 'policy_direct_rt'
option lookup 'main'
option suppress_prefixlength '0'
option priority '1100'
config rule 'policy_default_rt_vpn'
option mark '0x8000/0xc000'
option lookup '8000'
option priority '1101'
option invert '1'
config rule6 'policy_direct_rt6'
config rule6 'policy_default_rt_vpn6'
option invert '1'
config rule 'policy_default_rt_vpn_ts'
option priority '1099'
option mark '0x80000/0xc0000'
option invert '0'
config device
option type '8021q'
option ifname 'eth0'
option vid '20'
option name 'eth0.20'
config device
option type '8021q'
option ifname 'eth1'
option vid '30'
option name 'eth1.30'
config interface 'IOT30'
option device 'eth1.30'
option ipaddr '192.168.30.4'
config interface 'IOT20'
option device 'eth0.20'
option ipaddr '192.168.20.1'
config device
option type '8021q'
option ifname 'br-lan'
option vid '40'
option name 'br-lan.40'
config interface 'VLAN40'
option device 'br-lan.40'
option ipaddr '192.168.40.1'
root@GL-MT6000:~# cat /etc/config/wireless
config wifi-device 'mt798611'
option type 'mtk'
option band '2g'
option htmode 'HE40'
option channel 'auto'
option txpower '100'
option country 'US'
option random_bssid '1'
option legacy_rates '0'
option hwmode '11g'
config wifi-iface 'wifi2g'
option device 'mt798611'
option mode 'ap'
option network 'lan'
option ifname 'ra0'
option encryption 'psk2'
option wds '1'
option isolate '0'
option ieee80211k '1'
option bss_transition '1'
option ssid 'WhoWhatWhenWhereWifi'
option hidden '0'
option key 'password_0'
option macaddr 'MA:CA:D:RE:SS:18'
config wifi-device 'mt798612'
option type 'mtk'
option band '5g'
option htmode 'HE80'
option country 'US'
option disabled '0'
option hwmode '11a'
config wifi-iface 'wifi5g'
option device 'mt798612'
option mode 'ap'
option ifname 'rax0'
option wds '1'
option isolate '0'
option ssid 'WhoWhatWhenWhereWifi-5G'
option hidden '0'
option macaddr 'MA:CA:D:RE:SS:02'
config wifi-iface 'guest2g'
option network 'guest'
option mode 'ap'
option ifname 'ra1'
option key 'password_2'
option ssid 'GL-MT6000-a77-Guest'
option guest '1'
option wds '1'
option isolate '1'
option disabled '0'
option macaddr 'MA:CA:D:RE:SS:07'
config wifi-iface 'guest5g'
option mode 'ap'
option ifname 'rax1'
option ssid 'GL-MT6000-a77-5G-Guest'
option guest '1'
option disabled '1'
option wds '1'
option isolate '1'
option macaddr 'MA:CA:D:RE:SS:14'
config wifi-iface 'wifinet4'
option mode 'ap'
option key 'password_1'
option network 'IOT20'
option ssid 'IOT20-WIFI'
option disabled '1'
option macaddr 'MA:CA:D:RE:SS:21'
config wifi-iface 'wifinet5'
option mode 'ap'
option ssid 'IOT30-WIFI'
option network 'IOT30'
option macaddr 'MA:CA:D:RE:SS:04'
config wifi-iface 'wifinet6'
option mode 'ap'
option ssid 'IOT40-WIFI'
option network 'VLAN40'
option macaddr 'MA:CA:D:RE:SS:12'
root@GL-MT6000:~# cat /etc/config/dhcp
config dnsmasq
option domainneeded '1'
option boguspriv '1'
option filterwin2k '0'
option localise_queries '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option nonegcache '0'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto'
option nonwildcard '1'
option localservice '1'
option ednspacket_max '1232'
option rebind_protection '0'
config dhcp 'lan'
option interface 'lan'
option start '100'
option limit '150'
option leasetime '12h'
option dhcpv4 'server'
option ra_slaac '1'
option force '1'
option dhcpv6 'disabled'
option ra 'disabled'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
option loglevel '4'
config domain
option name 'console.gl-inet.com'
option ip '192.168.8.1'
config domain
option ip '::ffff:192.168.8.1'
config dhcp 'guest'
option interface 'guest'
option start '100'
option limit '150'
config dhcp 'secondwan'
option interface 'secondwan'
option ignore '1'
config host
option mac 'MA:CA:D:RE:SS:11'
option ip '192.168.222.38'
option tag 'device_07'
config host
option mac 'MA:CA:D:RE:SS:00'
option ip '192.168.222.35'
option tag 'device_09'
config host
option mac 'MA:CA:D:RE:SS:20'
option ip '192.168.222.16'
option tag 'device_11'
config host
option mac 'MA:CA:D:RE:SS:19'
option ip '192.168.222.29'
option tag 'device_06'
config host
option mac 'MA:CA:D:RE:SS:16'
option ip '192.168.222.18'
option tag 'device_05'
config host
option mac 'MA:CA:D:RE:SS:15'
option ip '192.168.222.19'
option tag 'device_04'
config host
option mac 'MA:CA:D:RE:SS:03'
option ip '192.168.222.20'
option tag 'device_10'
config host
option mac 'MA:CA:D:RE:SS:13'
option ip '192.168.222.17'
option tag 'device_00'
config host
option mac 'MA:CA:D:RE:SS:06'
option ip '192.168.222.15'
option tag 'device_02'
config host
option mac 'MA:CA:D:RE:SS:05'
option ip '192.168.222.14'
option tag 'device_03'
config host
option mac 'MA:CA:D:RE:SS:17'
option ip '192.168.222.5'
option tag 'device_12'
config host
option mac 'MA:CA:D:RE:SS:10'
option ip '192.168.222.30'
option tag 'device_01'
config host
option mac 'MA:CA:D:RE:SS:01'
option ip '192.168.222.4'
option tag 'device_08'
config dhcp 'IOT30'
option interface 'IOT30'
option start '100'
option limit '150'
list ra_flags 'none'
config dhcp 'IOT20'
option interface 'IOT20'
option ignore '1'
option start '100'
option limit '150'
config dhcp 'VLAN40'
option interface 'VLAN40'
option start '100'
option limit '150'
root@GL-MT6000:~# cat /etc/config/firewall
config defaults
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
option synflood_protect '1'
config zone
option name 'lan'
option forward 'ACCEPT'
list network 'lan'
config zone
option name 'wan'
option mtu_fix '1'
option input 'DROP'
option masq '1'
list network 'wan'
list network 'wan6'
list network 'wwan'
list network 'secondwan'
config forwarding
option src 'lan'
option dest 'wan'
option enabled '1'
config rule
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'bad-header'
option limit '1000/sec'
config rule
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule
option name 'Support-UDP-Traceroute'
option src 'wan'
option dest_port '33434:33689'
option proto 'udp'
option target 'REJECT'
option enabled 'false'
config include
config include 'nat6'
option path '/etc/firewall.nat6'
option reload '1'
config rule 'process_mark'
option name 'process_mark'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 65533'
option target 'MARK'
option set_xmark '0x8000/0xc000'
config rule 'process_mark_dns'
option name 'process_mark_dns'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 453'
config rule 'process_explict_vpn'
option name 'process_explict_vpn'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 20000'
option set_xmark '0x20000/0x20000'
config rule 'wan_in_conn_mark'
option name 'wan_in_conn_mark'
option src 'wan'
option dest '*'
option extra '-m mark --mark 0x0/0x3f00 -j CONNMARK --set-xmark 0x8000/0xc000'
option enabled '0'
config rule 'lan_in_conn_mark_restore'
option name 'lan_in_conn_mark_restore'
option src 'lan'
option dest '*'
option enabled '0'
option extra '-m connmark --mark 0x8000/0xc000 -j CONNMARK --restore-mark --nfmask 0xc000 --ctmask 0xc000'
config rule 'out_conn_mark_restore'
option name 'out_conn_mark_restore'
option dest '*'
option enabled '0'
config include 'swap_wan_in_conn_mark'
option type 'script'
option reload '1'
option path '/etc/firewall.swap_wan_in_conn_mark.sh'
option enabled '0'
config zone
option name 'guest'
option input 'REJECT'
list network 'guest'
config forwarding
option src 'guest'
option dest 'wan'
option enabled '1'
config rule
option name 'Allow-DHCP'
option src 'guest'
option proto 'udp'
option dest_port '67-68'
config rule
option name 'Allow-DNS'
option src 'guest'
option proto 'tcp udp'
option dest_port '53'
config include 'vpn_server_policy'
option path '/etc/firewall.vpn_server_policy.sh'
option reload '1'
option enabled '1'
config redirect
option enabled '1'
option src_dport '30303'
option dest_ip '192.168.222.35'
option dest_port '30303'
option src 'wan'
option name 'GL-Ethereum Execution Client'
option dest 'lan'
config redirect
option enabled '1'
option src_dport '9001'
option dest_port '9001'
option src 'wan'
option name 'GL-Ethereum Concensus Client'
option dest 'lan'
config redirect
option enabled '1'
option src_dport '4001'
option dest_ip '192.168.222.29'
option dest_port '4001'
option src 'wan'
option name 'GL-IPFS Ports'
option dest 'lan'
config rule 'sambasharewan'
option src 'wan'
option dest_port '137 138 139 445'
option dest_proto 'tcpudp'
option target 'DROP'
config rule 'sambasharelan'
option src 'lan'
config rule 'glnas_ser'
option src 'wan'
option dest_port '6000-6002'
option dest_proto 'tcp'
config rule 'webdav_wan'
option src 'wan'
option dest_port '6008'
config redirect 'dns_vpn'
option name 'dns for vpn'
option src 'lan'
option src_dport '53'
option dest 'lan'
option dest_port '1653'
option mark '!0x8000/0xc000'
list proto 'tcp'
list proto 'udp'
option enabled '0'
config redirect 'dns_vpn_guest'
option name 'dns for vpn guest'
option src 'guest'
option dest 'guest'
list proto 'tcp'
list proto 'udp'
option enabled '0'
config rule 'process_mark_stubby'
option name 'process_mark_stubby'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 410'
config include 'vpn_client_deal_leak'
option reload '1'
option path '/etc/firewall.vpn_client_deal_leak.sh'
option enabled '1'
config include 'glblock'
option path '/usr/bin/gl_block.sh'
option reload '1'
config zone
option name 'iot20'
config forwarding
option dest 'wan'
option src 'iot20'
config zone
option name 'iot30'
list network 'IOT30'
config zone
option name 'iot40'
list network 'VLAN40'
config forwarding
option src 'iot40'
option dest 'wan'
