Curl command is not working
hello, thanks,
issue wih my new axt1800, canont run curl
please advise,
david
curl
Error loading shared library libwolfssl.so.5.2.0.99a5b54a: No such file or directory (needed by /usr/bin/curl)
Error relocating /usr/bin/curl: curl_easy_header: symbol not found
Error relocating /usr/bin/curl: curl_easy_nextheader: symbol not found
i did the following and got errors
opkg update
opkg install libwolfssl5.2.0.99a5b54a
root@HOME01:/usr/sbin# curl
but this fixed the issue
opkg install libcurl
Maybe just old firmware.
curl runs well in the default firmware 4.0.1 release 5
thanks but cannot install beta software.
Why beta?
I’d think 4.0.1 release 5 means something like: ‘it is 4th version in the 0th variant and 1 upgrade (patch or feature) with the 5th bugfixed version’. This doesn’t sounds any beta for me.
Livecycle:
POC (Proof of Concept) - prototype - alpha - beta - RC (Release Candidate) - release - old - rusty - legacy - dead - died multiple times - used in German fortune 500 companies.
well, as per https://dl.gl-inet.com/?model=axt1800
the latest stable is v4.0.0
and as per https://dl.gl-inet.com/?model=axt1800&type=snapshot
v4.0.1.x is snapshot
Okay, you’re right. My fault.
Haven’t checked, just read the line. Some kind of confusing naming.
agreed, very confusing
