is it possible to use a plugin or something to set custom DNS servers (preferably TLS) for different LAN client’s by IP or MAC address? Or worst case 1 DNS service for main network, and a different one for the guest network
AdGuard Home is able to provide different upstream DNS servers per client. But in that case you won‘t be able to use VPN domain-based policies anymore.
Thank you. WIll look at Adguard home. I believe it is quite resource intensive though? While I’ll give it a go, happy to hear other suggestions if anyone knows.
Let me know if I am mistaken and Adguard home is not resource intensive
Are you able to use ssh or winscp?
If so you may want to look into dnsmasq tag and mac identifiers
Thanks. will have a look at SSH - I have basic linux skills
Yup you can there use list dhcp_option="6,dnsip"
and it will serve a dns for that mac or tag.
Depends on your router.
