Custom DNS settings
I’m new to GL-iNet routers and am a bit confused about specifying upstream DNS server addresses. I want to use IPv4 DNS servers 1.1.1.2 and 9.9.9.9, and IPv6 DNS servers 2606:4700:4700::1111 and 2620:fe::fe. There seems to be 2 different places to specify these addresses, but I suspect they may have differences. Those places are
  1. Admin > Network > DNS > DNS Server Settings
  2. LuCI > Network > DHCP and DNS > DNS forwardings
I would guess that the LuCI definitions take precedence but I haven’t seen that stated. Is that true?
Do it on then GLinet UI and that will be enough.
Okay. I’ve deleted the LuCI definitions. Is there any way to tell what DNS server is actually being used?
This site will list what your DNS results return.
If you changed the DNS to cloudflare you can also use
Also try https://www.dnsleaktest.com
I have been looking at this recently, There are three that I have found. I do not use luci I am not sure it will work as expected.
  1. This one tells clients to use the routers IP for DNS # EG: 192.168.8.1
    DNS > DNS Server Settings DNS Server 1 1.1.1.2 DNS Server 2 9.9.9.9
  2. This one tells clients to use the The IP you specify for DNS # EG: in your case 1.1.1.2 and 9.9.9.9
    Network Settings > Lan DNS > DHCP Server > DNS Server 11.1.1.2 DNS Server 2 9.9.9.9
Example 2 is the same as using option 6 in dnsmasq
I am using mt6000 with beta firmware
