Custom DOH option and temperature in router overview request
Hello guys,
I want to ask if is possible to add the option for custom dns over http DOH. I have search in all the options and is not there. I know i can set it up in LuCi but i prefer to dont do to many changes there.
I want to use the DoH from NextDNS and will be nice if will have same options as DoT. Just to add the ID.
Also will be nice if we have a temperature small widget or information in the router overview. Flint2
Thank you very much for your feedback and comments.
Dot currently supports the NextDNS, but does not support ID fields. We will collect the relevant requirements and hand to PM to evaluate.
The current temperature display is for built-in fan router (Related to fan adjustment), for no fan may not be considered to add the temperature monitoring.
In general, the temperature display may cause some users to worry that the router will overheat or something wrong, but the actual operating temperature < 80°C (long time) will not affect the operation of the router.
Hello Bruce,
DoT NextDns support the ID but not DoH. Hope to be implemented in future. Also any news for update on op24?
Currently, R&D resources are concentrated on v4.8 firmware (closed source), op24 may follow the v4.8.0 update, but also need to wait for v4.8.0 (closed source) to verify whether it is stable before op24-4.8.0 will be released.
Ok thanks for info bruce
