I started from cloning gl-inet github repo .
I did as instructed:
./scripts/feeds update -a
./scripts/feeds install -a
Then make menuconfig and error appeared as such:
When attempting to compile, the build failed with this error.
What can I do to correct this problem?
It is warning, just ignore it.
It is not a warning. As I stated, the build failed with this error .
I can’t see you had built it. You just only execute make menuconfig , which is a command of configuration.
Johnex
March 26, 2019, 12:09pm
5
As Kyson wrote, you will always get a warning when running make menuconfig, its a bug in the OpenWrt toolchain.
Can you post a screenshot of the actual error when building?
This is normal - as mentioned above…
make menuconfig is only one part of the build process - one you select your options, when you exit, then do make…
Might want to review here…
Build system usage * Do everything as an unprivileged user, not root, without sudo. * Make sure there are no spaces in the full path to the build directory. There is an issue affecting the current OpenWrt source tree (from at least 21.02...
I am quite familiar with openwrt build system, and this build error is a result of missing dependencies. How do I get pass this error to make the build?
Johnex. I posted that error. It is exactly the same one, except I took the screenshot from the make menuconfig instead. Exactly the same error.
alzhao
March 27, 2019, 10:48am
9
Why not just post the full screenshot so that everybody just believe you.
Johnex
March 27, 2019, 10:54am
10
I don’t see the build failing from your screenshot. Show where it fails?
We already told you that on GL builds there are such warnings too.
Thanks guy for trying. I got help from the friend who introduced this router and she resolved the build errors by editing some config.
Can you share the fixes please? I have the same problem.
