Custom TLS certificates gone after upgrade
I just installed the latest firmware for Flint 2.
I haven’t tested the firmware itself, but I am either blinded from other posts, or something is wrong with the upgrade process.
So, I have installed my own certificates under the /etc/ngninx. And since I wanted to be sure that the certificates and the key will not be overwritten by an upgrade process, I actually installed them with my own names and made the nginx.cer and nginx.key to be soft links to the actual files.
Now, they are gone! And actually, the whole /etc/nginx directory is overwritten since my files are not there! Which means that the upgrade process will not be smooth in the future as well.
Thus:
  1. How do we install our custom certificates so as they are not overwritten by the upgrade process?
  2. I think it’s wrong to replace a target directory. Devs should take into account the possibility that we have modified those directories!
The easiest way to make them permanent is to add them to /etc/sysupgrade.conf
You have two options:
Use them without your own name and add each certificate path to /etc/sysupgrade.conf or use your own names and add the whole /etc/nginx to /etc/sysupgrade.conf
The last option could create issues whenever GL changes nginx config in upgrade, but it should work fine mostly.
Lovely!
The idea is to keep intervention as little as possible. So, use the same names and add them to sysupgrade.conf
Many many thanks.
P.S. I still think it’s wrong to replace the whole directory during an upgrade.
No, it isn’t! The devs are constantly optimizing and improving Nginx’s performance and security.
