Custom x750 Firmware help @alzhao @hogan
Hey looking to get assistance from @alzhao @hogan again since you guys are always so helpful in the past with the custom firmware and saving the custom firewall script needed for TTL bypass for my customers units
iptables -t mangle -D POSTROUTING -j TTL --ttl-set 65
iptables -t mangle -I POSTROUTING 1 -j TTL --ttl-set 65
email [email protected]
Have you been able to compile a custom firmware now?
If yes, these command can be just put in /etc/rc.local
No i haven’t i but i need the firmware file for customers so even after hard resets i wouldn’t have to personally do it over and over
Do you only need to set the TTL of the modem?
The 3.105 firmware version already supports this feature.
You can set the TTL by manual setting.
