Customize Routing Rules for Wireguard Client
I want to use the Customize Routing Rules because I want a specific device to bypass VPN and certain domains e.g. offerup (and associated IP) to bypass VPN as well. Currently I can't use both Mac based and Target Domain Based at the same time. I tried to use Customize Routing Rules, but it seems like now my entire network is not using VPN by default before I can even set any rules. Is this by design and you have to explicitly allow your network to use VPN? I am new to networking so not sure if this is supposed to be the default behavior of the setting. Appreciate any assistance.
The VPN Proxy Mode supports the diversion of domain and IP, or specify the client devices.
That is temporarily have not support the select dual mode enabled at the same time.
In the future period, we will consider developing such features like this. I will submit it to PM.
Thanks.
