It is possible to customize the tor UI? for GLI UI you can diretly edit it, not sure it is also in Tor UI. If yes, where it is located?
Yes you can, as it is open source.
It is in luci
/usr/lib/lua/luci/
Thanks a lot. already found it.
It is in luci
/usr/lib/lua/luci/
