Is it possible to set dark theme as default for the UI. Right now, I have to select dakr theme Everytime I login from different device or browser
Thanks
Thanks
An easy way to do this is to modify the files in /www/theme/
. Swap /www/theme/default/index.css
and /www/theme/dark/index.css
Wouldn’t it be possible to select the right theme based on browser preference in future releases?
Something like the code below should help you out:
// Check to see if Media-Queries are supported
if (window.matchMedia) {
// Check if the dark-mode Media-Query matches
if(window.matchMedia('(prefers-color-scheme: dark)').matches){
// Dark
} else {
// Light
} else {
// Default (when Media-Queries are not supported)
Wouldn’t this be overwritten during update?
Yes, it will, so you may need a script that executes a bit after each upgrade, for example
mv /www/theme/default/index.css /www/theme/dark/index1.css
mv /www/theme/dark/index.css /www/theme/default/index.css
mv /www/theme/dark/index1.css /www/theme/dark/index.css
Good idea, we will test it.
