Do any GL-iNet travel routers support tethering or data through the same USB Type-C power connector?
Only the Brume (MV1000(W))
MV1000 supports that. Connect it directly to your PC and it will work as Ethernet.
E750 also support that. But you must use the port replicator to split into power and Ethernet.
@alzahao Can you elaborate how to achieve this on E750 ?
E750 comes with a port replicator. You should have that with the product. It does not do the same as MV1000 which connect directly to your computer’s USB port.
