wifird
I’ve tried pasting some DD-WRT firewall rules (below) in OpenWRT but it doesn’t seem to work.
Does anyone know if there is something slightly different with the code on OpenWRT?
iptables -I FORWARD -d 108.175.32.0/255.255.240.0 -j REJECT
iptables -I FORWARD -d 198.38.96.0/255.255.224.0 -j REJECT
iptables -I FORWARD -d 198.45.48.0/255.255.240.0 -j REJECT
alzhao
2
why it doesn’t work? iptables should be the same.
You tried to block several IP address right?
I am not good at this but maybe you can just use firewall settings.
https://wiki.openwrt.org/doc/uci/firewall
Block access to a specific host
The following rule blocks all connection attempts to the specified host address.
config rule
option src lan
option dest wan
option dest_ip 123.45.67.89
option target REJECT
