I have had no luck flashing dd-wrt to the 6414, despite following http://www.gl-inet.com/w/?p=561. I have no problems entering the u-boot web interface, but uploading the factory-to-ddwrt.bin for the 703n causes the flashing process to hang, and even after waiting 5 min before power cycling, the device never reboots. Fortunately I can go back to stock using the 6416’s OEM firmware downloaded from this site.
Any suggestions are appreciated, and would be super excited if someone compiled a dd-wrt for this device.
OK, making progress. The firmware you link to is the same that can be downloaded from dd-wrt.com (I diffed the files). Now dd-wrt is working. I didn’t initially understand that it appears that the LAN ethernet port seems to be disabled in dd-wrt (probably because the original firmware is for a 1xEthernet device). Once I configured via wireless, everything seems to be working.
It is good to know that you can easily return dd-wrt to its defaults by holding the reset button until the red light goes off.
Sorry my fault firmware r27805 for tplink_tl-wr710nv1 try again there no wifi connection, i have no ide about that, first time i try it’s working now. But now it not, i’ll be update is there if i found what wrong
Connect LAN cable to port LAN .
After flash if you didn’t get dhcp ip change your cable to WAN port. it should be fine
the you can see the dd-wrt.
I hope it will help some one…
Note:
If you already flash dd-wrt wr703 then you want to flash again using Failsafe mode. for your safe please save you setting and default factory. is not when flash to wr710n your setting will be no change (it will store). just be careful about that…
Can you help me understand how to flash my router (6416) in DD-wrt?
I’m not entirely zero, I can access the “Failsafe” and communicate Telnet (I’m on Windows 10), I can not send the new software on it, with a video I perhaps understand better . My problem is that I find no tutorial “clear”, I am French and I quite magnifying step tutorials on English because I do not understand English too.
Since no tutorial available in French, I expect once I understood everything, posting the tutorial in French on the forum to help other people like me.
PS: sorry about the translation with Google translation.
Bonjour,
Pouvez-vous m’aider comprendre comment flasher mon router(6416) sous DD-wrt ?
Je ne suis pas totalement nul, j’arrive à accéder au “Failsafe” et a communiquer en Telnet (je suis sous windows 10), je n’arrive pas en envoyer le nouveau logiciel dessus, avec une vidéo je comprendrais peut-être mieux. Mon problème est que je ne trouve aucun tutoriel “claire”, je suis français et je loupe pas mal d’étape sur les tutoriels anglais car je ne comprend pas trop l’anglais.
Comme aucun tutoriel existe en français, je compte, une fois avoir tout compris, poster le tutoriel en français sur le forum pour aider d’autre personne comme moi.
PS : désolé de la traduction avec Google traduction.
