DDNS not updating using AR750S
I have a Wireguard Server running on my AR750S. The AR750S is behind my ISP supplied router, connected by a LAN cable. I have a time switch on the ISP router and get a different IPv4 address most days.
If I query my IP address using nslookup it does not update.
$nslookup xxxxxxx.glddns.com 1.1.1.1
Server: 1.1.1.1
Address: 1.1.1.1#53
Non-authoritative answer:
Address: 86.178.xxx.xxx
The address displayed is (I believe) a correct but old address. The same address is returned by 8.8.8.8
This means that I cannot connect to the Wireguard server when away from home.
I have forwarded the default Wireguard port to the AR750S on the ISPs router. No other ports are forwarded.
This used to work a couple of months ago and I think this stopped working when I upgraded the AR750 software, but I am not sure.
Current software is as follows:
AR750S: 3.025
Plug-ins:
gl-ddns 3.0.21.1
gl-cloud-ui 3.0.18-1
On the Cloud Management page GoodCloud is switched OFF, but if switched ON it shows ‘device connect cloud server success’ so there is an internet connection.
Dynamic DDNS is enabled (Green slide switch visible) and APPLY has been pushed
DDNS test says ‘Your DDNS is not effective yet. Please try later’ and has shown this since 0700 this morning.
It is now 10.30 am.
I am not using Goodcloud management or Remote access so no other ports are forwarded to this router.
Finally, I tried rebooting the router and nothing changes.
Can anyone suggest what is wrong?
I just reflashed my router last night and couldn’t get it working until I installed gl-ddns 3.0.22-1…may try that or the other ddns plugins for openwrt
We just had a problem of the ddns server in the past day.
Can you pls try again? If not working correctly pls pm your ddns and we will find out.
A further comment: I tried looking for an update as mentioned by [Sonomascanner] , but couldn’t see it.
I reinstalled gl-cloud-ui (3.0.13-1)and gl-ddns (3.0.18-1) these are earlier versions than before. I am not sure why?
With this set up I turn DDNS on (switch goes green). If I then click on ‘Plug-ins’ and then back to ‘Remote Access’ the DDNS seems to have been switched OFF (Not green but grey) This seems unreasonable.
Pls don’t install these two services manually.
If not working well, maybe you can send the log to check.
I have reflashed the 3.025 firmware and am now back to
gl-ddns 3.0.21.1
gl-cloud-ui 3.0.18-1.
My first issue is that when I switch ON the DDNS, Apply does not change and pressing it does not seem to save the new state. When I reload the webpage DDNS enabled is NOT GREEN.
logread gives: front removed due to length.
Thu Nov 28 13:08:16 2019 daemon.info dnsmasq[2804]: using local addresses only for domain local
Thu Nov 28 13:08:16 2019 daemon.info dnsmasq[2804]: using local addresses only for domain invalid
Thu Nov 28 13:08:16 2019 daemon.info dnsmasq[2804]: using local addresses only for domain bind
Thu Nov 28 13:08:16 2019 daemon.info dnsmasq[2804]: using nameserver 127.0.0.1#53535
Thu Nov 28 13:08:16 2019 daemon.info dnsmasq[2804]: using local addresses only for domain lan
Thu Nov 28 13:08:16 2019 daemon.info dnsmasq[2804]: read /etc/hosts - 4 addresses
Thu Nov 28 13:08:16 2019 daemon.info dnsmasq[2804]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Thu Nov 28 13:08:16 2019 daemon.info dnsmasq-dhcp[2804]: read /etc/ethers - 0 addresses
Thu Nov 28 13:08:16 2019 daemon.notice netifd: Interface ‘wan6’ is now up
Thu Nov 28 13:08:17 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:08:17 2019 kern.alert kernel: [ 62.597781] fast-classifier: starting up
Thu Nov 28 13:08:17 2019 kern.alert kernel: [ 62.602043] fast-classifier: registered
Thu Nov 28 13:08:18 2019 daemon.warn odhcpd[2235]: DHCPV6 CONFIRM IA_NA from 0001000124b7f0f5dca6320e83f6 on br-lan: not on-link
Thu Nov 28 13:08:18 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Thu Nov 28 13:08:18 2019 kern.info kernel: [ 63.017549] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Thu Nov 28 13:08:18 2019 kern.info kernel: [ 63.102957] br-lan: port 2(wlan1) entered blocking state
Thu Nov 28 13:08:18 2019 kern.info kernel: [ 63.108451] br-lan: port 2(wlan1) entered disabled state
Thu Nov 28 13:08:18 2019 kern.info kernel: [ 63.114335] device wlan1 entered promiscuous mode
Thu Nov 28 13:08:18 2019 daemon.err rmmod: module is not loaded
Thu Nov 28 13:08:18 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e4:95:6e:45:a6:04 and ssid “Juno_nomap_optout”
Thu Nov 28 13:08:18 2019 kern.warn kernel: [ 63.237591] ip11:10.254.254.1 lan_ip[0].IP=afefe01
Thu Nov 28 13:08:18 2019 kern.warn kernel: [ 63.242673] ip12:192.168.9.1 lan_ip[1].IP=c0a80901
Thu Nov 28 13:08:18 2019 daemon.info dnsmasq[2804]: read /etc/hosts - 4 addresses
Thu Nov 28 13:08:18 2019 daemon.info dnsmasq[2804]: read /tmp/hosts/odhcpd - 0 addresses
Thu Nov 28 13:08:18 2019 daemon.info dnsmasq[2804]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Thu Nov 28 13:08:18 2019 daemon.info dnsmasq-dhcp[2804]: read /etc/ethers - 0 addresses
Thu Nov 28 13:08:18 2019 kern.warn kernel: [ 63.280850] Version:3.0.5 Date:201801210
Thu Nov 28 13:08:18 2019 daemon.warn odhcpd[2235]: DHCPV6 SOLICIT IA_NA from 0001000124b7f0f5dca6320e83f6 on br-lan: ok fd49:e630:dac7:10::35a/128
Thu Nov 28 13:08:18 2019 daemon.warn odhcpd[2235]: DHCPV6 REQUEST IA_NA from 0001000124b7f0f5dca6320e83f6 on br-lan: ok fd49:e630:dac7:10::35a/128
Thu Nov 28 13:08:19 2019 daemon.info dnsmasq[2804]: read /etc/hosts - 4 addresses
Thu Nov 28 13:08:19 2019 daemon.info dnsmasq[2804]: read /tmp/hosts/odhcpd - 1 addresses
Thu Nov 28 13:08:19 2019 daemon.info dnsmasq[2804]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Thu Nov 28 13:08:19 2019 daemon.info dnsmasq-dhcp[2804]: read /etc/ethers - 0 addresses
Thu Nov 28 13:08:20 2019 kern.info kernel: [ 64.892948] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Thu Nov 28 13:08:20 2019 kern.info kernel: [ 64.899705] br-lan: port 2(wlan1) entered blocking state
Thu Nov 28 13:08:20 2019 kern.info kernel: [ 64.905199] br-lan: port 2(wlan1) entered forwarding state
Thu Nov 28 13:08:20 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Thu Nov 28 13:08:20 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Thu Nov 28 13:08:20 2019 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Thu Nov 28 13:08:20 2019 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/radvd
Thu Nov 28 13:08:20 2019 user.notice ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Thu Nov 28 13:08:20 2019 daemon.notice netifd: Network device ‘wlan1’ link is up
Thu Nov 28 13:08:20 2019 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Thu Nov 28 13:08:21 2019 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Thu Nov 28 13:08:21 2019 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Thu Nov 28 13:08:21 2019 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Thu Nov 28 13:08:22 2019 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Thu Nov 28 13:08:22 2019 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Thu Nov 28 13:08:22 2019 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Thu Nov 28 13:08:23 2019 user.notice ucitrack: Setting up /etc/config/mwan3 reload trigger for non-procd /etc/init.d/mwan3
Thu Nov 28 13:08:25 2019 daemon.info dnsmasq-dhcp[2804]: DHCPDISCOVER(br-lan) dc:a6:32:0e:83:f5
Thu Nov 28 13:08:25 2019 daemon.info dnsmasq-dhcp[2804]: DHCPOFFER(br-lan) 10.254.254.216 dc:a6:32:0e:83:f5
Thu Nov 28 13:08:25 2019 daemon.info dnsmasq-dhcp[2804]: DHCPREQUEST(br-lan) 10.254.254.216 dc:a6:32:0e:83:f5
Thu Nov 28 13:08:25 2019 daemon.info dnsmasq-dhcp[2804]: DHCPACK(br-lan) 10.254.254.216 dc:a6:32:0e:83:f5 IV
Thu Nov 28 13:08:25 2019 daemon.notice procd: /etc/rc.d/S95done: killall: uqmi: no process killed
Thu Nov 28 13:08:26 2019 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN2G
Thu Nov 28 13:08:26 2019 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN5G
Thu Nov 28 13:19:34 2019 user.info : Sta config not set!!!
Thu Nov 28 13:19:38 2019 user.notice firewall: Reloading firewall due to ifup of wan (eth0.2)
Thu Nov 28 13:19:39 2019 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Thu Nov 28 13:19:39 2019 daemon.notice hostapd: wlan1: AP-DISABLED
Thu Nov 28 13:19:39 2019 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Thu Nov 28 13:19:39 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Thu Nov 28 13:19:39 2019 kern.info kernel: [ 78.125901] device wlan1 left promiscuous mode
Thu Nov 28 13:19:39 2019 kern.info kernel: [ 78.130641] br-lan: port 2(wlan1) entered disabled state
Thu Nov 28 13:19:39 2019 daemon.notice netifd: Network device ‘wlan1’ link is down
Thu Nov 28 13:19:41 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Thu Nov 28 13:19:41 2019 kern.info kernel: [ 80.705799] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Thu Nov 28 13:19:42 2019 kern.info kernel: [ 80.823897] br-lan: port 2(wlan1) entered blocking state
Thu Nov 28 13:19:42 2019 kern.info kernel: [ 80.829443] br-lan: port 2(wlan1) entered disabled state
Thu Nov 28 13:19:42 2019 kern.info kernel: [ 80.835257] device wlan1 entered promiscuous mode
Thu Nov 28 13:19:42 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e4:95:6e:45:a6:04 and ssid “Juno_nomap_optout”
Thu Nov 28 13:19:43 2019 kern.info kernel: [ 82.337863] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Thu Nov 28 13:19:43 2019 kern.info kernel: [ 82.344632] br-lan: port 2(wlan1) entered blocking state
Thu Nov 28 13:19:43 2019 kern.info kernel: [ 82.350154] br-lan: port 2(wlan1) entered forwarding state
Thu Nov 28 13:19:43 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->ENABLED
Thu Nov 28 13:19:43 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Thu Nov 28 13:19:43 2019 daemon.notice netifd: Network device ‘wlan1’ link is up
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Clearing IPv4 filter table
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Clearing IPv4 nat table
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Clearing IPv4 mangle table
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Populating IPv4 filter table
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-DHCP-Renew’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-Ping’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-IGMP’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-IPSec-ESP’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-ISAKMP’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘guestzone_DHCP’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘guestzone_DNS’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-Wireguard’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Forward ‘lan’ → ‘wan’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Forward ‘guestzone’ → ‘wan’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Forward ‘wireguard’ → ‘wan’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Forward ‘wireguard’ → ‘lan’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Forward ‘lan’ → ‘wireguard’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Forward ‘guestzone’ → ‘wireguard’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Forward ‘wireguard’ → ‘guestzone’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Zone ‘lan’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Zone ‘wan’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Zone ‘guestzone’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Zone ‘wireguard’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Populating IPv4 nat table
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Populating IPv4 mangle table
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Clearing IPv6 filter table
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Clearing IPv6 mangle table
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Populating IPv6 filter table
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-DHCPv6’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-MLD’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-ICMPv6-Input’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Rule ‘Allow-ICMPv6-Forward’
Thu Nov 28 13:19:44 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Populating IPv6 mangle table
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Set tcp_ecn to off
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Set tcp_syncookies to on
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Set tcp_window_scaling to on
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Running script ‘/etc/firewall.user’
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: iptables: No chain/target/match by that name.
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: ipset v6.34: The set with the given name does not exist
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: iptables v1.6.2: can’t initialize iptables table raw': Table does not exist (do you need to insmod?) Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: Perhaps iptables or your kernel needs to be upgraded. Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: iptables v1.6.2: can't initialize iptables table raw’: Table does not exist (do you need to insmod?)
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: ! Failed with exit code 3
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Running script ‘/usr/bin/glfw.sh’
Thu Nov 28 13:19:45 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: uci: Entry not found
Thu Nov 28 13:19:46 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: uci: Entry not found
Thu Nov 28 13:19:47 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Running script ‘/usr/sbin/glqos.sh’
Thu Nov 28 13:19:48 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: ifconfig: br-guest: error fetching interface information: Device not found
Thu Nov 28 13:19:48 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: * Running script ‘/var/etc/mwan3.include’
Thu Nov 28 13:19:49 2019 user.notice firewall: Reloading firewall due to ifup of wan6 (eth0.2)
Thu Nov 28 13:19:50 2019 daemon.notice procd: /etc/rc.d/S99wireguard_server: /sbin/uci: Invalid argument
Thu Nov 28 13:19:52 2019 daemon.info procd: - init complete -
Thu Nov 28 13:19:54 2019 kern.notice kernel: [ 92.848583] random: crng init done
Thu Nov 28 13:19:54 2019 kern.notice kernel: [ 92.852108] random: 6 urandom warning(s) missed due to ratelimiting
Thu Nov 28 13:19:54 2019 daemon.info urandom_seed[4282]: Seed saved (/etc/urandom.seed)
Thu Nov 28 13:19:56 2019 user.err : can not found token file.
Thu Nov 28 13:20:27 2019 daemon.info hostapd: wlan1: STA c0:10:b1:0a:13:aa IEEE 802.11: authenticated
Thu Nov 28 13:20:27 2019 daemon.info hostapd: wlan1: STA c0:10:b1:0a:13:aa IEEE 802.11: associated (aid 1)
Thu Nov 28 13:20:28 2019 daemon.notice hostapd: wlan1: AP-STA-CONNECTED c0:10:b1:0a:13:aa
Thu Nov 28 13:20:28 2019 daemon.info hostapd: wlan1: STA c0:10:b1:0a:13:aa RADIUS: starting accounting session A49724DB4C84E702
Thu Nov 28 13:20:28 2019 daemon.info hostapd: wlan1: STA c0:10:b1:0a:13:aa WPA: pairwise key handshake completed (RSN)
Thu Nov 28 13:20:28 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:20:31 2019 daemon.info dnsmasq-dhcp[2804]: DHCPDISCOVER(br-lan) c0:10:b1:0a:13:aa
Thu Nov 28 13:20:31 2019 daemon.info dnsmasq-dhcp[2804]: DHCPOFFER(br-lan) 10.254.254.212 c0:10:b1:0a:13:aa
Thu Nov 28 13:20:31 2019 daemon.info dnsmasq-dhcp[2804]: DHCPREQUEST(br-lan) 10.254.254.212 c0:10:b1:0a:13:aa
Thu Nov 28 13:20:31 2019 daemon.info dnsmasq-dhcp[2804]: DHCPACK(br-lan) 10.254.254.212 c0:10:b1:0a:13:aa
Thu Nov 28 13:20:32 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:23:12 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:24:17 2019 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Thu Nov 28 13:24:37 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:25:00 2019 daemon.info dnsmasq-dhcp[2804]: DHCPREQUEST(br-lan) 10.254.254.216 dc:a6:32:0e:83:f5
Thu Nov 28 13:25:00 2019 daemon.info dnsmasq-dhcp[2804]: DHCPACK(br-lan) 10.254.254.216 dc:a6:32:0e:83:f5 IV
Thu Nov 28 13:25:05 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:25:09 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:25:13 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:25:17 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:27:09 2019 daemon.info dnsmasq-dhcp[2804]: DHCPREQUEST(br-lan) 10.254.254.216 dc:a6:32:0e:83:f5
Thu Nov 28 13:27:09 2019 daemon.info dnsmasq-dhcp[2804]: DHCPACK(br-lan) 10.254.254.216 dc:a6:32:0e:83:f5 IV
Thu Nov 28 13:27:10 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:27:14 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:27:18 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:27:22 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:28:58 2019 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Thu Nov 28 13:31:26 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:34:34 2019 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Thu Nov 28 13:35:52 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:39:39 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:40:07 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:47:43 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:49:21 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 13:54:59 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 14:03:56 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 14:09:10 2019 daemon.info dnsmasq-dhcp[2804]: DHCPREQUEST(br-lan) 10.254.254.135 84:a9:3e:06:10:b6
Thu Nov 28 14:09:10 2019 daemon.info dnsmasq-dhcp[2804]: DHCPACK(br-lan) 10.254.254.135 84:a9:3e:06:10:b6 Silver
Thu Nov 28 14:09:12 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 14:09:16 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 14:09:20 2019 daemon.warn odhcpd[2235]: A default route is present but there is no public prefix on br-lan thus we don’t announce a default route!
Thu Nov 28 14:09:24 2019 authpriv.info dropbear[14687]: Child connection from 10.254.254.135:59742
Thu Nov 28 14:09:31 2019 authpriv.notice dropbear[14687]: Password auth succeeded for ‘root’ from 10.254.254.135:59742
I hope this helps…
Tony
The non-latching switch issue was caused by not ticking the ‘Agree’ box.
My DDNS has now updated to the correct IP address. Apart from reflashing, I’m not clear what else fixed the problem.
Tony
Wireguard is now working too.
Thanks alzhao
Good to know! Good to know!
A post was split to a new topic: Your DDNS is not effective yet
