do I need to do port forwarding for DDNS(without enabling https or ssh access) to work? If so, which port do I need to forward? do I need to do port forward to my secondary router’s ip? or just doing port forwarding enough?
2.for https or ssh access, Do I need to port forwarding to my secondary router’s ip? or just doing port forwarding enough? Thanks in advance.
For DDNS itself, you do not need to do anything. Because DDNS is that, the router report its public IP address to the DDNS server. So the DDNS will be resolved as your public IP.
But if you want to access the router or anything via the ddns, you need to do port forward via the main router. So for your 2nd question, you need to port forward from your main router to the GL routers
Thanks again. #1 step - DDNS itself is not working and seeing this message “this router is behind NAT or you do not have a public IP address” while doing DDNS TEST. Please help
