Device Model:
- GL-MT6000 Flint2
Firmware version:
- 4.6.2
Screenshots:
Network topology diagram:
- ISP Modem <---> Flint2 <----> Eero 6+ in bridge mode <---> Wifi Devices
Problem Description:
I've spent a whole day searching forums and reddit posts but have been unable to determine if this is an issue or just an incompatibility.
When I enable a VPN Client using "Domain Based VPN Policies" Set to only use the VPN for the whitelisted domains (Ex: Only use VPN for google.com) running a DDNS test fails with the error.
"The DNS record for this DDNS domain could not be found by the DNS server. Please check the Internet connection of the device"
Upon immediately disabling the VPN client profile, running the DDNS test works without any errors.
Services from GL.iNet Use VPN is set to DISABLED.
The only other thing I've enabled is to use AdGuard for DNS filtering.
System Logs:
Summary
Mon Jul 15 15:56:29 2024 kern.info kernel: [ 814.808440] hook is going to be disabled !
Mon Jul 15 15:56:29 2024 daemon.err rmmod: unloading the module failed
Mon Jul 15 15:56:44 2024 daemon.info dnsmasq[5180]: exiting on receipt of SIGTERM
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: Connected to system UBus
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: started, version 2.85 cachesize 150
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: DNS service limited to local subnets
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: UBus support enabled: connected to system bus
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq-dhcp[14860]: DHCP, IP range 10.0.0.100 -- 10.0.0.249, lease time 12h
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: using only locally-known addresses for domain test
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: using only locally-known addresses for domain onion
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: using only locally-known addresses for domain localhost
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: using only locally-known addresses for domain invalid
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: using only locally-known addresses for domain bind
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: using nameserver 127.0.0.1#1653 for domain google.com
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: using nameserver 127.0.0.1#1653 for domain reddit.com
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: using nameserver 127.0.0.1#3053
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: using only locally-known addresses for domain lan
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: read /etc/hosts - 4 addresses
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[14860]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq-dhcp[14860]: read /etc/ethers - 0 addresses
Mon Jul 15 15:56:45 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Mon Jul 15 15:56:45 2024 user.warn : skip line without '=' Default
Mon Jul 15 15:56:45 2024 daemon.notice netifd: Network device 'wgclient' link is up
Mon Jul 15 15:56:45 2024 daemon.notice netifd: Interface 'wgclient' is now up
Mon Jul 15 15:56:45 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_6167 group_5485 group_8452 group_737 peer_517 CONFIG_cfg030f15_ports=
Mon Jul 15 15:56:45 2024 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15590]: Connected to system UBus
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: started, version 2.85 cache disabled
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: DNS service limited to local subnets
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: UBus support enabled: connected to system bus
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq-dhcp[15592]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: using only locally-known addresses for domain test
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: using only locally-known addresses for domain onion
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: using only locally-known addresses for domain localhost
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: using only locally-known addresses for domain invalid
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: using only locally-known addresses for domain bind
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: using only locally-known addresses for domain lan
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: using nameserver 127.0.0.1#3053
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: read /etc/hosts - 4 addresses
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq[15592]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Jul 15 15:56:45 2024 daemon.info dnsmasq-dhcp[15592]: read /etc/ethers - 0 addresses
Mon Jul 15 15:56:45 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/gl_ddns/dynamic_dns_updater.sh -- stop
Mon Jul 15 15:56:46 2024 user.notice ddns-scripts[7783]: glddns: PID '7783' terminated by 'SIGTERM' at 2024-07-15 15:56
Mon Jul 15 15:56:47 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/gl_ddns/dynamic_dns_updater.sh -- start
Mon Jul 15 15:56:47 2024 user.notice ddns-scripts[15924]: ddns: PID '15924' started at 2024-07-15 15:56
Mon Jul 15 15:56:47 2024 user.warn ddns-scripts[15924]: ddns: Service section disabled! - TERMINATE
Mon Jul 15 15:56:47 2024 user.notice ddns-scripts[15927]: glddns: PID '15927' started at 2024-07-15 15:56
Mon Jul 15 15:56:47 2024 user.warn ddns-scripts[15924]: ddns: PID '15924' exit WITH ERROR '1' at 2024-07-15 15:56
Mon Jul 15 15:56:47 2024 user.warn ddns-scripts[15927]: glddns: NO valid IP found
