This was working fine before but not sure if a recent update broke it. Currently when VPN client is enabled, DDNS is not showing the correct IP. The setting to exclude glinet services from vpn is properly set. I tried restarting router, toggling on off vpn and enabling and disabling setting to send glinet services via vpn. Seeing this issue on Slate AX (GL-AXT1800) Wi-Fi. Version 4.7.0
I seem to be able to reproduce your situation, will ask for R&D to check this.
About the DDNS IP issue, we are aware this on AXT1800 v4.7.0, here is the temp workaround, next firmware version will improve this issue.
- Download this file, and unzip it.
gl_ddns.zip (539 Bytes) - Upload the file "gl_ddns" to router AXT1800 path "/root/" through WinSCP, and execute the commands on SSH:
mv /root/gl_ddns /etc/init.d/gl_ddns
chmod +x /etc/init.d/gl_ddns
/etc/init.d/gl_ddns restart
Update:
The latest firmware v4.8.2 has resolved this issue.
Please update to the latest firmware version for AXT1800/Slate AX and AX1800/Flint.
