I am currently unable to flash my device through the failsafe debricking method. before I am able to load a file, I get “request file name too long” let me know if you have any suggestions.
U-Boot 1.1.4 (Fri May 17 09:44:06 2019)
ar300m - Honey Bee 2.0DRAM:
sri
Honey Bee 2.0
ath_ddr_initial_config(195): (16bit) ddr2 init
ath_sys_frequency: cpu 650 ddr 597 ahb 216
tap = 0x00000003
Tap (low, high) = (0x8, 0x23)
Tap values = (0x15, 0x15, 0x15, 0x15)
128 MB
Flash Manuf Id 0xef, DeviceId0 0x40, DeviceId1 0x18
flash size 16MB, sector count = 256
Power up PLL with outdiv = 0 then switch to 3
*** Warning *** : PCIe WLAN Module not found !!!
ath_gmac_enet_initialize...
No valid address in Flash. Using fixed address
ath_gmac_enet_initialize: reset mask:c02200
Honey Bee ---->S27 PHY*
S27 reg init
: cfg1 0x800c0000 cfg2 0x7114
eth0: 00:03:7f:09:0b:ad
eth0 up
Honey Bee ----> MAC 1 S27 PHY *
S27 reg init
ATHRS27: resetting s27
ATHRS27: s27 reset done
: cfg1 0x800c0000 cfg2 0x7214
eth1: 00:03:7f:09:0b:ad
eth1 up
eth0, eth1
Qualcomm Atheros SPI NAND Driver, Version 0.1 (c) 2014 Qualcomm Atheros Inc.
ath_spi_nand_ecc: Couldn't enable internal ECC
Setting 0x181162c0 to 0x58b1a100
Press reset button for at least:
- 5 sec. to run web failsafe mode
Reset button is pressed for: 5
Button was pressed for 5 sec...
HTTP server is starting for firmware update...
enet1 port0 up
HTTP server is starting at IP: 192.168.1.1
HTTP server is ready!
## Error: request file name too long!
