Debugging 2.4 GHz Device Dropouts
Problem with my GL-MT3000
I’ve got a device (Chord Electronics Poly) that has a solid connection via 2.4 GHz when at home. As soon as I take it to my office it connects and then drops the connection after a minute or so.
Chord are buying a GL-MT3000 to test this with to see if it’s their product that has an issue. I think it might be environmental.
How do I get logs or otherwise find out info about the connection and disconnection of this device to see what is going on? I’d love to see a big smoking gun saying “disconnect because of X” and then I can fix it.
So far I’ve gone through various setups using all the different channels and all the different wifi standards in case AC caused an issue and it uses just b/g/n at the moment. Nothing changes sadly.
Any help would be great. Thanks.
Has anyone had a chance to think about this? I’d love some help if possible.
Why does my 2.4 GHz device connect and drop off in certain environments.
At home and at another location it is fine, but in my office the problem happens.
Check the logs on the Routers UI to see what’s going on. Maybe something useful is written there.
I know enough to look for the devices MAC address in the logs; would it say error or blocked or something to indicate what happened?
Maybe, maybe not. You need to post the logs here then.
Thanks. I can see something that may be useful. The MAC address has been masked with xx
Thu Mar 14 08:23:21 2024 kern.debug kernel: [  516.265921] [add_dev_config 307]add node success. iface:wan, dev:eth0, ifindex:2
Thu Mar 14 08:24:57 2024 kern.notice kernel: [  612.216502] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:24:57 2024 kern.debug kernel: [  612.229413] entrytb_aid_aquire(): found non-occupied aid:7, allocated from:4
Thu Mar 14 08:24:57 2024 kern.warn kernel: [  612.236475] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:xx:xx:xx:xx:xx:xx
Thu Mar 14 08:24:57 2024 kern.notice kernel: [  612.246241] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:24:57 2024 kern.notice kernel: [  612.255516] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:24:57 2024 kern.notice kernel: [  612.264613] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:24:57 2024 kern.notice kernel: [  612.270630] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:24:58 2024 kern.notice kernel: [  612.391619] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:24:58 2024 kern.notice kernel: [  612.398245] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:24:58 2024 kern.notice kernel: [  612.405014] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:24:58 2024 kern.notice kernel: [  612.411640] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Mar 14 08:24:58 2024 kern.warn kernel: [  612.423163] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from xx:xx:xx:xx:xx:xx
Thu Mar 14 08:25:00 2024 kern.notice kernel: [  614.458766] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=4]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:25:00 2024 kern.notice kernel: [  614.475351] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:25:00 2024 kern.notice kernel: [  614.485026] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:25:00 2024 kern.notice kernel: [  614.494238] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:25:00 2024 kern.notice kernel: [  614.500259] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:25:00 2024 kern.notice kernel: [  614.611139] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:25:01 2024 kern.notice kernel: [  615.626909] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:25:02 2024 kern.notice kernel: [  616.650696] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:25:03 2024 kern.err kernel: [  617.673794] 7981@C15L1,WpaEAPOLRetryAction() 7675: 4Way-MSG1 timeout with xx:xx:xx:xx:xx:xx
Thu Mar 14 08:25:03 2024 kern.notice kernel: [  617.682150] 7981@C15L3,MlmeDeAuthAction() 1399: Send DEAUTH frame with ReasonCode(15) to xx:xx:xx:xx:xx:xx
Thu Mar 14 08:25:03 2024 kern.warn kernel: [  617.691901] 7981@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=0
Thu Mar 14 08:25:03 2024 kern.notice kernel: [  617.698063] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Thu Mar 14 08:25:03 2024 kern.warn kernel: [  617.705179] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:36 2024 kern.notice kernel: [  770.892924] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:36 2024 kern.debug kernel: [  770.905939] entrytb_aid_aquire(): found non-occupied aid:7, allocated from:4
Thu Mar 14 08:27:36 2024 kern.warn kernel: [  770.913012] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:36 2024 kern.notice kernel: [  770.923383] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:36 2024 kern.notice kernel: [  770.932674] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:36 2024 kern.notice kernel: [  770.941829] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:36 2024 kern.notice kernel: [  770.947999] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:36 2024 kern.notice kernel: [  771.069161] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:36 2024 kern.notice kernel: [  771.075800] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:27:36 2024 kern.notice kernel: [  771.082528] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:27:36 2024 kern.notice kernel: [  771.089155] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Mar 14 08:27:36 2024 kern.warn kernel: [  771.100669] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:37 2024 kern.notice kernel: [  772.001273] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=4]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:37 2024 kern.notice kernel: [  772.016714] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:37 2024 kern.notice kernel: [  772.026408] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:37 2024 kern.notice kernel: [  772.035602] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:37 2024 kern.notice kernel: [  772.041670] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:37 2024 kern.notice kernel: [  772.152929] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:37 2024 kern.notice kernel: [  772.159603] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:27:37 2024 kern.notice kernel: [  772.166415] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:27:37 2024 kern.notice kernel: [  772.173701] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Mar 14 08:27:37 2024 kern.warn kernel: [  772.185564] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:39 2024 kern.notice kernel: [  774.169518] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=4]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:39 2024 kern.notice kernel: [  774.184778] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:39 2024 kern.notice kernel: [  774.194020] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:39 2024 kern.notice kernel: [  774.203096] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:39 2024 kern.notice kernel: [  774.209110] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:40 2024 kern.notice kernel: [  774.320482] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:40 2024 kern.notice kernel: [  774.335476] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:27:40 2024 kern.notice kernel: [  774.342218] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:27:40 2024 kern.notice kernel: [  774.348910] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Mar 14 08:27:40 2024 kern.warn kernel: [  774.360434] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:41 2024 daemon.info dnsmasq-dhcp[3462]: DHCPDISCOVER(br-lan) xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:41 2024 daemon.info dnsmasq-dhcp[3462]: DHCPOFFER(br-lan) 192.168.8.200 xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:42 2024 kern.notice kernel: [  776.428021] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=4]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:42 2024 kern.notice kernel: [  776.444318] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:42 2024 kern.notice kernel: [  776.453581] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:42 2024 kern.notice kernel: [  776.462697] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:42 2024 kern.notice kernel: [  776.468743] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:42 2024 kern.notice kernel: [  776.580041] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:42 2024 kern.notice kernel: [  776.586826] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:27:42 2024 kern.notice kernel: [  776.593736] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:27:42 2024 kern.notice kernel: [  776.600459] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Mar 14 08:27:42 2024 kern.warn kernel: [  776.612016] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.452952] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=4]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.471523] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.480757] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.489845] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.495864] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.607543] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.614301] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.621049] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:27:44 2024 kern.warn kernel: [  778.627748] 7981@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=0
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.633903] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Thu Mar 14 08:27:44 2024 kern.warn kernel: [  778.641409] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:44 2024 kern.notice kernel: [  778.648584] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-389) from xx:xx:xx:xx:xx:xx, reason=6
Thu Mar 14 08:27:44 2024 kern.warn kernel: [  778.788643] 7981@C08L2,ap_peer_disassoc_action() 3479: ASSOC - 1 receive DIS-ASSOC request
Thu Mar 14 08:27:45 2024 kern.notice kernel: [  779.863500] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:45 2024 kern.debug kernel: [  779.876409] entrytb_aid_aquire(): found non-occupied aid:7, allocated from:4
Thu Mar 14 08:27:45 2024 kern.warn kernel: [  779.883467] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:45 2024 kern.notice kernel: [  779.893243] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:45 2024 kern.notice kernel: [  779.902489] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:45 2024 kern.notice kernel: [  779.911571] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:45 2024 kern.notice kernel: [  779.917593] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:45 2024 kern.notice kernel: [  780.039257] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:45 2024 kern.notice kernel: [  780.045909] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:27:45 2024 kern.notice kernel: [  780.052671] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:27:45 2024 kern.notice kernel: [  780.059336] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Mar 14 08:27:45 2024 kern.warn kernel: [  780.070845] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:47 2024 kern.warn kernel: [  781.770512] 7981@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=0
Thu Mar 14 08:27:47 2024 kern.notice kernel: [  781.776678] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Thu Mar 14 08:27:47 2024 kern.warn kernel: [  781.783840] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:47 2024 kern.notice kernel: [  781.791003] 7981@C08L3,ap_peer_deauth_action() 429: AUTH - receive DE-AUTH(seq-471) from xx:xx:xx:xx:xx:xx, reason=7
Thu Mar 14 08:27:48 2024 kern.notice kernel: [  782.345714] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:48 2024 kern.debug kernel: [  782.358665] entrytb_aid_aquire(): found non-occupied aid:7, allocated from:4
Thu Mar 14 08:27:48 2024 kern.warn kernel: [  782.365733] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:48 2024 kern.notice kernel: [  782.379088] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:48 2024 kern.notice kernel: [  782.388377] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:48 2024 kern.notice kernel: [  782.397657] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:48 2024 kern.notice kernel: [  782.404250] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:48 2024 kern.notice kernel: [  782.526772] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:48 2024 kern.notice kernel: [  782.533400] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:27:48 2024 kern.notice kernel: [  782.540129] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:27:48 2024 kern.notice kernel: [  782.546756] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Mar 14 08:27:48 2024 kern.warn kernel: [  782.558257] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:49 2024 kern.notice kernel: [  784.059777] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=4]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:49 2024 kern.notice kernel: [  784.075897] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:49 2024 kern.notice kernel: [  784.085341] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:49 2024 kern.notice kernel: [  784.094461] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:49 2024 kern.notice kernel: [  784.100726] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:49 2024 kern.notice kernel: [  784.210338] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:49 2024 kern.notice kernel: [  784.216959] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:27:49 2024 kern.notice kernel: [  784.223734] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:27:49 2024 kern.notice kernel: [  784.230491] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Mar 14 08:27:50 2024 kern.warn kernel: [  784.242024] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:52 2024 kern.notice kernel: [  786.932020] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=4]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:52 2024 kern.notice kernel: [  786.947321] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:52 2024 kern.notice kernel: [  786.956751] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:52 2024 kern.notice kernel: [  786.965903] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:52 2024 kern.notice kernel: [  786.971986] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:52 2024 kern.notice kernel: [  787.081550] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:52 2024 kern.notice kernel: [  787.088817] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Thu Mar 14 08:27:52 2024 kern.notice kernel: [  787.095567] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Thu Mar 14 08:27:52 2024 kern.notice kernel: [  787.107476] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Thu Mar 14 08:27:52 2024 kern.warn kernel: [  787.119008] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:53 2024 daemon.info dnsmasq-dhcp[3462]: DHCPDISCOVER(br-lan) xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:53 2024 daemon.info dnsmasq-dhcp[3462]: DHCPOFFER(br-lan) 192.168.8.200 xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:53 2024 daemon.info dnsmasq-dhcp[3462]: DHCPREQUEST(br-lan) 192.168.8.200 xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:53 2024 daemon.info dnsmasq-dhcp[3462]: DHCPACK(br-lan) 192.168.8.200 xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:55 2024 kern.notice kernel: [  789.921552] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=4]xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:55 2024 kern.notice kernel: [  789.936799] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:55 2024 kern.notice kernel: [  789.946042] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Thu Mar 14 08:27:55 2024 kern.notice kernel: [  789.955127] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Thu Mar 14 08:27:55 2024 kern.notice kernel: [  789.961146] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Thu Mar 14 08:27:55 2024 kern.notice kernel: [  790.072622] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:56 2024 kern.notice kernel: [  791.104453] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:57 2024 kern.notice kernel: [  792.128372] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Thu Mar 14 08:27:58 2024 kern.err kernel: [  793.151112] 7981@C15L1,WpaEAPOLRetryAction() 7675: 4Way-MSG1 timeout with xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:58 2024 kern.notice kernel: [  793.159470] 7981@C15L3,MlmeDeAuthAction() 1399: Send DEAUTH frame with ReasonCode(15) to xx:xx:xx:xx:xx:xx
Thu Mar 14 08:27:58 2024 kern.warn kernel: [  793.169452] 7981@C01L2,wifi_sys_disconn_act() 1002:  wdev_idx=0
Thu Mar 14 08:27:58 2024 kern.notice kernel: [  793.176282] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Thu Mar 14 08:27:58 2024 kern.warn kernel: [  793.183379] 7981@C13L2,MacTableDeleteEntry() 1793: Del Sta:xx:xx:xx:xx:xx:xx
So, we are not smarter than before, I guess.
Duh! I forgot I have an OpenAI account. I’ll use that in future.
So there is a time out and it seems to be uncertain what the cause is.
Maybe it’s the number of SSIDs in the area, but I’ve be been to worse places.
I’ve just updated to 4.5.7 firmware because I heard some people say 2.4 GHz is improved, but no luck.
At home and elsewhere all is good, but anywhere in my office building it just won’t work.
We discussed previously that it’s not making the WPA2 connection completely, but I have no idea how to debug this.
hmm for the timeout message it could also be related to usb interference can you check if that is maybe the case?
Especially USB3-devices are well known for disturbing 2.4GHz WLAN.
I’ll try that. The device is a small standalone audio player so I can place it anywhere and make sure there is no USB device anywhere near it and that it is not plugged into any USB device itself.
Okay, new developments. I’m assuming the difference is the update to firmware 4.5.7.
First the audio player now connects fine, but then after a short period it disconnects. Looking at the logs compared to last time and it connects correctly. The disconnect is the device choosing to disconnect according to my ChatGPT analysis.
I was able to find a printer and a phone that both have 2.4GHz capabilities. Both also fail with the same issue. Unlike the audio device they have a screen so can give me an error result. They both said password problem.
The phone has connected to the Beryl before and so the password is fine. The printer is new to Beryl and we typed in the password three times and double-triple checked it. Again it connects then disconnected saying password error.
This is a new development and makes me think it’s the Beryl’s 2.4GHz function that’s failing now.
Is there a known issue with this?
Using WPA2 + WPA3?
If that’s the case, reduce to WPA2 only.
Sometimes it can also be the cipher being used, when these devices uses wpa2 and you used wpa2/wpa3 mixed then the chance is that it doesn’t work, or its only working with the opposite cipher.
Note when you change it, i recommend to also reconfigure these devices by deleting their known wifi settings because i do know if you change these ciphers these devices can keep stuck on a eapol key or handshake key which does not exist.
Some devices especially a little older ones can be a bit misbehaving on cipher changes, so if something changed in a update (often should not be the problem) this could be a possibility.
Okay, thanks. The weird bit is this location based thing.
Like I’m in a hotel now and I was on a train today and there was no problem connecting. Yet once I’m in the office building it goes wrong.
I’ll try to restart everything as you said next time I’m in the office and see if it works.
Well, Wi-Fi is a shared medium. Office buildings like co working spaces might create interferences.
This ended up solving it. I turned of WiFi AX and completely reconfigured everything including passwords, SSID on client and Beryl and now it all works.
Thanks.
