Default modem setup for Spitz-AX3000
What are the default modem setup for this router?
I am trying to get back to factory setting, after some tinkering as the modem doesn’t get me internet
This is what i have and i wonder if this is messed up?
AT+QCFG=“data_interface”,1,0
AT+QETH=“eth_driver”,“r8125”,1
AT+QCFG=“pcie/mode”,1
AT+QCFG=“usbnet”,1
AT+QMAPWAC=1
T+CGDCONT=
AT+QPRTPARA=1
AT+CFUN=1,1
Can someone comment?
Where did you get these AT commands from ?
Google searches, since i am not able to get connected.
In anycase, i want to go back to facotry settings.
How do i do this?
I tried installing firmware and the only firmware i can install is 4.3.0
This firmware is old and has bugs in it. It keeps asking me to upgrade to new firmware.
When i try all other firmware puts this router in continuous reboot mode.
I also tried to use qfirehose to flash the Quectel RM520NGL modem inside using the July 2023 version. I am still stuck.
I just want to get back to factory settings, so any answers to wards that will be get.
Can you please help?
I was able to get everything up and working, after i used the command: AT+QMAPWAC=0
If, AT+QMAPWAC=1, then i had no access to modem
So i installed, minicom and used: minicom -D /dev/ttyUSB2 to send the command AT+QMAPWAC=0
Then i rebooted and got back the modem interface.
Why does the command :AT+QMAPWAC=1, not work in the X3000 ?
Can you help please?
Yes, this seems to be a common issue within the quectel modem, not GL device:
http://www.huangyunzeng.com/sw
https://telekomhilft.telekom.de/t5/Festnetz-Internet/Hybrid-5G-Empfaenger-SE-QR-Code/m-p/6067869#M1567119
