I just bought a used GL-AR300M16-ext from a guy on eBay. I’m unable to factory reset the device such that it presents the initial login screen as described here:
using the Repair or Reset procedures found here:
I’ve tried the password reset procedure at least 10 times but the device’s web page always asks for a password. The guy I bought it from said that the unit came with a Sonos system he got from Costco. I suspect the device has a custom firmware on it to support the Sonos implementation. Does anyone know what the default password might be in this configuration?
Thanks in advance!
Rob
