kiltym
#1
I have an MT1300. Running 3.211.
I am seeing the following in my logs, which is causing WiFi drops on my network:
Thu Jun 30 09:44:27 2022 daemon.warn apcli[4023]: not found ap(HUERTA DON CHANO)…re-scan in 60s
This is an old WiFi network that is no longer in use. However, when I go to Saved Networks, I have nothing listed. “No Known WiFi Networks”.
So, it seems the value is still in a file somewhere, but not showing up in the UI.
Is there a file I can check and remove the entry from so I can stop the WiFi disconnects?
Thank you.
alzhao
#2
You can reboot the device. If still have the problem, ssh to the router and clear the sta
config in /etc/config/wireless
kiltym
#3
Thank you.
The reboot had not worked.
How much of the ‘sta’ entry should I remove? All of it so there is no ‘sta’ entry? Or everything under the ‘sta’? Or just some of it?
Thanks for the clarification.
alzhao
#4
Remove the whole part of sta
Also remove all in /etc/config/ssids
kiltym
#5
Thank you.
Ssids was empty, but removed the entire sta section.
Thanks again.
