/dev/diag on Mudi V2
Hi GL.iNET Support,
I recently purchased the GL.iNET Mudi V2 Travel Router (GL-E750V2) and really like the device.
Do you think it might be possible to add thediagcharkernel module in one of the next firmwares to be able to get a /dev/diag device for the Qualcomm chip?
Thanks in advance
meb
OpenWrt does not appear to use /dev/diag as the diagnostic interface for cellular modules.
If you need to capture QXDM logs, please refer to:
Get Module Logs - GL.iNet Router Docs 4
If for executing AT commands, see:
Cellular - GL.iNet Router Docs 4
