Devices disconnecting from router repeating captive portal wifi
Hey guys,
I’m currently sitting in an airport and wanted to repeat their captive portal wifi via my ATX 1800 router. I followed the GLI net guide and everything worked as expected - Im online!
However, every few minutes, my devices (macbook, phone) got disconnected from the router. Im currently trying to figure if this is a protection protocol by the airport wifi or if my router is having a bad time with repeating this signal.
What’s curious is that my devices got disconnected from my router. The router didnt lose power and was still broadcasting its signal. I just had to reconnect my devices and they were back online. It seems like I was kicked off by the network admin, yknow?
Here’s some logs:
Im hoping some you network sleuths can solve this mystery.
Thu Jul 27 14:25:20 2023 kern.info kernel: [ 2641.038030] br-lan: port 4(wlan0-1) entered forwarding state
Thu Jul 27 14:25:21 2023 daemon.err hostapd: 80/80+80 MHz: center segment 1 wrong or no second channel offset
Thu Jul 27 14:25:27 2023 daemon.err hostapd: 80/80+80 MHz: center segment 1 wrong or no second channel offset
Thu Jul 27 14:25:30 2023 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED b8:e6:0c:0e:8a:d9 0 0
Thu Jul 27 14:25:30 2023 daemon.info hostapd: wlan0-1: STA b8:e6:0c:0e:8a:d9 IEEE 802.11: authenticated
Thu Jul 27 14:25:30 2023 daemon.info hostapd: wlan0-1: STA b8:e6:0c:0e:8a:d9 IEEE 802.11: associated (aid 1)
Thu Jul 27 14:25:30 2023 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED b8:e6:0c:0e:8a:d9 0 0
Thu Jul 27 14:25:30 2023 daemon.info hostapd: wlan0-1: STA b8:e6:0c:0e:8a:d9 RADIUS: starting accounting session 70C67FCF05659A43
Thu Jul 27 14:25:30 2023 daemon.info hostapd: wlan0-1: STA b8:e6:0c:0e:8a:d9 WPA: pairwise key handshake completed (RSN)
Thu Jul 27 14:25:31 2023 daemon.info dnsmasq-dhcp[2169]: DHCPREQUEST(br-lan) 192.168.8.227 b8:e6:0c:0e:8a:d9
Thu Jul 27 14:25:31 2023 daemon.info dnsmasq-dhcp[2169]: DHCPACK(br-lan) 192.168.8.227 b8:e6:0c:0e:8a:d9 DK-MAC-MITH
Thu Jul 27 14:25:31 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: WNM: Disassociation Imminent - Disassociation Timer 40
Thu Jul 27 14:25:31 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: WNM: Preferred List Available
Thu Jul 27 14:25:31 2023 kern.debug kernel: [ 2652.658359] wlan-sta0: Limiting TX power to 5 dBm as advertised by 74:a2:e6:5b:e1:af
// LOST CONNECTION HERE
Thu Jul 27 14:25:33 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: Unknown event 62
Thu Jul 27 14:25:33 2023 daemon.err hostapd: 80/80+80 MHz: center segment 1 wrong or no second channel offset
Thu Jul 27 14:25:35 2023 daemon.notice netifd: Network device 'wlan-sta0' link is down
Thu Jul 27 14:25:35 2023 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Thu Jul 27 14:25:35 2023 kern.info kernel: [ 2656.616860] wlan-sta0: disassociated from 74:a2:e6:5b:e1:af (Reason: 1=UNSPECIFIED)
Thu Jul 27 14:25:35 2023 daemon.notice netifd: wwan (21776): udhcpc: received SIGTERM
Thu Jul 27 14:25:35 2023 daemon.notice netifd: wwan (21776): udhcpc: unicasting a release of 192.168.92.143 to 1.1.1.1
Thu Jul 27 14:25:35 2023 daemon.notice netifd: wwan (21776): udhcpc: sending release
Thu Jul 27 14:25:35 2023 daemon.notice netifd: wwan (21776): udhcpc: entering released state
Thu Jul 27 14:25:35 2023 daemon.notice netifd: wwan (21776): Command failed: Permission denied
Thu Jul 27 14:25:35 2023 daemon.notice netifd: Interface 'wwan' is now down
Thu Jul 27 14:25:35 2023 daemon.info avahi-daemon[3887]: Withdrawing address record for 192.168.92.143 on wlan-sta0.
Thu Jul 27 14:25:35 2023 daemon.info avahi-daemon[3887]: Leaving mDNS multicast group on interface wlan-sta0.IPv4 with address 192.168.92.143.
Thu Jul 27 14:25:35 2023 daemon.info avahi-daemon[3887]: Interface wlan-sta0.IPv4 no longer relevant for mDNS.
Thu Jul 27 14:25:35 2023 daemon.notice netifd: Interface 'wwan' is disabled
Thu Jul 27 14:25:35 2023 daemon.notice netifd: Interface 'wwan' is enabled
Thu Jul 27 14:25:35 2023 daemon.warn dnsmasq[2169]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu Jul 27 14:25:36 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: CTRL-EVENT-DISCONNECTED bssid=74:a2:e6:5b:e1:af reason=1
Thu Jul 27 14:25:36 2023 daemon.notice wpa_supplicant[2829]: BSSID 74:a2:e6:5b:e1:af ignore list count incremented to 2, ignoring for 10 seconds
Thu Jul 27 14:25:36 2023 user.notice mwan3[23425]: Execute ifdown event on interface wwan (unknown)
Thu Jul 27 14:25:36 2023 user.info mwan3track[22438]: Detect ifdown event on interface wwan (wlan-sta0)
Thu Jul 27 14:25:36 2023 user.notice mwan3track[22438]: Interface wwan (wlan-sta0) is offline
Thu Jul 27 14:25:36 2023 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 27 14:25:36 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: Reject scan trigger since one is already pending
Thu Jul 27 14:25:36 2023 daemon.warn wpa_supplicant[2829]: wlan-sta0: Failed to initiate AP scan
Thu Jul 27 14:25:36 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: SME: Trying to authenticate with 74:a2:e6:5b:e1:af (SSID='CPH Airport Free Wi-Fi' freq=5240 MHz)
Thu Jul 27 14:25:36 2023 kern.info kernel: [ 2656.971702] wlan-sta0: authenticate with 74:a2:e6:5b:e1:af
Thu Jul 27 14:25:36 2023 kern.info kernel: [ 2657.058008] wlan-sta0: send auth to 74:a2:e6:5b:e1:af (try 1/3)
Thu Jul 27 14:25:36 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: Trying to associate with 74:a2:e6:5b:e1:af (SSID='CPH Airport Free Wi-Fi' freq=5240 MHz)
Thu Jul 27 14:25:36 2023 kern.info kernel: [ 2657.059761] wlan-sta0: authenticated
Thu Jul 27 14:25:36 2023 kern.info kernel: [ 2657.068292] wlan-sta0: associate with 74:a2:e6:5b:e1:af (try 1/3)
Thu Jul 27 14:25:36 2023 daemon.notice netifd: Network device 'wlan-sta0' link is up
Thu Jul 27 14:25:36 2023 daemon.notice netifd: Interface 'wwan' has link connectivity
Thu Jul 27 14:25:36 2023 daemon.notice netifd: Interface 'wwan' is setting up now
Thu Jul 27 14:25:36 2023 kern.info kernel: [ 2657.070313] wlan-sta0: RX AssocResp from 74:a2:e6:5b:e1:af (capab=0x1101 status=0 aid=3)
Thu Jul 27 14:25:36 2023 kern.info kernel: [ 2657.075085] wlan-sta0: associated
Thu Jul 27 14:25:36 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: Associated with 74:a2:e6:5b:e1:af
Thu Jul 27 14:25:36 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: CTRL-EVENT-CONNECTED - Connection to 74:a2:e6:5b:e1:af completed [id=0 id_str=]
Thu Jul 27 14:25:36 2023 daemon.err hostapd: 80/80+80 MHz: center segment 1 wrong or no second channel offset
Thu Jul 27 14:25:36 2023 daemon.notice netifd: wwan (23623): udhcpc: started, v1.33.2
Thu Jul 27 14:25:36 2023 daemon.notice netifd: wwan (23623): udhcpc: sending discover
Thu Jul 27 14:25:36 2023 kern.debug kernel: [ 2657.178669] wlan-sta0: Limiting TX power to 5 dBm as advertised by 74:a2:e6:5b:e1:af
Thu Jul 27 14:25:36 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Thu Jul 27 14:25:36 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: Unknown event 62
Thu Jul 27 14:25:36 2023 kern.info kernel: [ 2657.317465] ath11k c000000.wifi: bss color param 0x80000000 set on vdev 1
Thu Jul 27 14:25:37 2023 user.notice firewall: Reloading firewall due to ifdown of wwan ()
Thu Jul 27 14:25:38 2023 daemon.err repeater: (/usr/sbin/repeater:1156) NO IP for long time, down/up wlan-sta0
Thu Jul 27 14:25:38 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: CTRL-EVENT-DISCONNECTED bssid=74:a2:e6:5b:e1:af reason=3 locally_generated=1
Thu Jul 27 14:25:38 2023 daemon.notice wpa_supplicant[2829]: BSSID 74:a2:e6:5b:e1:af ignore list count incremented to 2, ignoring for 10 seconds
Thu Jul 27 14:25:38 2023 daemon.notice netifd: Network device 'wlan-sta0' link is down
Thu Jul 27 14:25:38 2023 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Thu Jul 27 14:25:38 2023 daemon.notice netifd: wwan (23623): udhcpc: read error: Network is down, reopening socket
Thu Jul 27 14:25:38 2023 kern.info kernel: [ 2659.489336] wlan-sta0: deauthenticating from 74:a2:e6:5b:e1:af by local choice (Reason: 3=DEAUTH_LEAVING)
Thu Jul 27 14:25:38 2023 daemon.notice netifd: wwan (23623): udhcpc: received SIGTERM
Thu Jul 27 14:25:38 2023 daemon.notice netifd: wwan (23623): udhcpc: entering released state
Thu Jul 27 14:25:38 2023 daemon.notice netifd: wwan (23623): Command failed: Permission denied
Thu Jul 27 14:25:38 2023 daemon.notice netifd: Interface 'wwan' is now down
Thu Jul 27 14:25:38 2023 daemon.notice netifd: Interface 'wwan' is disabled
Thu Jul 27 14:25:38 2023 daemon.notice netifd: Interface 'wwan' is enabled
Thu Jul 27 14:25:39 2023 user.notice mwan3[24003]: Execute ifdown event on interface wwan (unknown)
Thu Jul 27 14:25:39 2023 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 27 14:25:39 2023 daemon.err hostapd: 80/80+80 MHz: center segment 1 wrong or no second channel offset
Thu Jul 27 14:25:39 2023 daemon.notice netifd: Network device 'wlan0-1' link is down
Thu Jul 27 14:25:39 2023 kern.info kernel: [ 2660.488629] br-lan: port 4(wlan0-1) entered disabled state
Thu Jul 27 14:25:39 2023 kern.info kernel: [ 2660.491971] ath11k c000000.wifi: bss color param 0x80000000 set on vdev 1
Thu Jul 27 14:25:39 2023 kern.info kernel: [ 2660.493489] br-lan: port 4(wlan0-1) entered forwarding state
Thu Jul 27 14:25:39 2023 kern.info kernel: [ 2660.499948] br-lan: port 4(wlan0-1) entered forwarding state
Thu Jul 27 14:25:39 2023 daemon.notice netifd: Network device 'wlan0-1' link is up
Thu Jul 27 14:25:39 2023 user.notice firewall: Reloading firewall due to ifdown of wwan ()
Thu Jul 27 14:25:40 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: SME: Trying to authenticate with 74:a2:e6:5b:e1:af (SSID='CPH Airport Free Wi-Fi' freq=5240 MHz)
Thu Jul 27 14:25:40 2023 kern.info kernel: [ 2661.001361] wlan-sta0: authenticate with 74:a2:e6:5b:e1:af
Thu Jul 27 14:25:40 2023 kern.info kernel: [ 2661.003754] wlan-sta0: send auth to 74:a2:e6:5b:e1:af (try 1/3)
Thu Jul 27 14:25:40 2023 kern.info kernel: [ 2661.006889] wlan-sta0: authenticated
Thu Jul 27 14:25:40 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: Trying to associate with 74:a2:e6:5b:e1:af (SSID='CPH Airport Free Wi-Fi' freq=5240 MHz)
Thu Jul 27 14:25:40 2023 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 27 14:25:40 2023 daemon.notice netifd: Network device 'wlan-sta0' link is up
Thu Jul 27 14:25:40 2023 daemon.notice netifd: Interface 'wwan' has link connectivity
Thu Jul 27 14:25:40 2023 daemon.notice netifd: Interface 'wwan' is setting up now
Thu Jul 27 14:25:40 2023 kern.info kernel: [ 2661.148360] wlan-sta0: associate with 74:a2:e6:5b:e1:af (try 1/3)
Thu Jul 27 14:25:40 2023 kern.info kernel: [ 2661.150647] wlan-sta0: RX AssocResp from 74:a2:e6:5b:e1:af (capab=0x1101 status=0 aid=4)
Thu Jul 27 14:25:40 2023 kern.info kernel: [ 2661.156163] wlan-sta0: associated
Thu Jul 27 14:25:40 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: Associated with 74:a2:e6:5b:e1:af
Thu Jul 27 14:25:40 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: CTRL-EVENT-CONNECTED - Connection to 74:a2:e6:5b:e1:af completed [id=0 id_str=]
Thu Jul 27 14:25:40 2023 daemon.err hostapd: 80/80+80 MHz: center segment 1 wrong or no second channel offset
Thu Jul 27 14:25:40 2023 daemon.notice netifd: wwan (24292): udhcpc: started, v1.33.2
Thu Jul 27 14:25:40 2023 daemon.notice netifd: wwan (24292): udhcpc: sending discover
Thu Jul 27 14:25:40 2023 kern.debug kernel: [ 2661.248784] wlan-sta0: Limiting TX power to 5 dBm as advertised by 74:a2:e6:5b:e1:af
Thu Jul 27 14:25:40 2023 daemon.notice netifd: wwan (24292): udhcpc: sending select for 192.168.92.143
Thu Jul 27 14:25:40 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Thu Jul 27 14:25:40 2023 kern.info kernel: [ 2661.387728] ath11k c000000.wifi: bss color param 0x80000000 set on vdev 1
Thu Jul 27 14:25:40 2023 daemon.notice netifd: wwan (24292): udhcpc: lease of 192.168.92.143 obtained, lease time 7175
Thu Jul 27 14:25:40 2023 daemon.info avahi-daemon[3887]: Joining mDNS multicast group on interface wlan-sta0.IPv4 with address 192.168.92.143.
Thu Jul 27 14:25:40 2023 daemon.info avahi-daemon[3887]: New relevant interface wlan-sta0.IPv4 for mDNS.
Thu Jul 27 14:25:40 2023 daemon.info avahi-daemon[3887]: Registering new address record for 192.168.92.143 on wlan-sta0.IPv4.
Thu Jul 27 14:25:40 2023 daemon.notice netifd: Interface 'wwan' is now up
Thu Jul 27 14:25:40 2023 daemon.info dnsmasq[2169]: reading /tmp/resolv.conf.d/resolv.conf.auto
Thu Jul 27 14:25:40 2023 daemon.info dnsmasq[2169]: using only locally-known addresses for domain test
Thu Jul 27 14:25:40 2023 daemon.info dnsmasq[2169]: using only locally-known addresses for domain onion
Thu Jul 27 14:25:40 2023 daemon.info dnsmasq[2169]: using only locally-known addresses for domain localhost
Thu Jul 27 14:25:40 2023 daemon.info dnsmasq[2169]: using only locally-known addresses for domain invalid
Thu Jul 27 14:25:40 2023 daemon.info dnsmasq[2169]: using only locally-known addresses for domain bind
Thu Jul 27 14:25:40 2023 daemon.info dnsmasq[2169]: using only locally-known addresses for domain lan
Thu Jul 27 14:25:40 2023 daemon.info dnsmasq[2169]: using nameserver 1.1.1.1#53
Thu Jul 27 14:25:40 2023 daemon.info dnsmasq[2169]: using nameserver 1.0.0.1#53
Thu Jul 27 14:25:40 2023 user.info mwan3track[22438]: Detect ifdown event on interface wwan (wlan-sta0)
Thu Jul 27 14:25:41 2023 user.info mwan3track[22438]: Lost 2 ping(s) on interface wwan (wlan-sta0)
Thu Jul 27 14:25:41 2023 user.notice mwan3[24481]: Execute ifup event on interface wwan (wlan-sta0)
Thu Jul 27 14:25:41 2023 user.notice mwan3[24481]: Starting tracker on interface wwan (wlan-sta0)
Thu Jul 27 14:25:41 2023 user.notice mwan3track[22438]: Stopping mwan3track for interface "wwan"
Thu Jul 27 14:25:43 2023 user.info mwan3rtmon[4451]: Detect rtchange event.
Thu Jul 27 14:25:43 2023 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta0)
Thu Jul 27 14:25:44 2023 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED b8:e6:0c:0e:8a:d9 0 0
Thu Jul 27 14:25:44 2023 daemon.info hostapd: wlan0-1: STA b8:e6:0c:0e:8a:d9 IEEE 802.11: authenticated
Thu Jul 27 14:25:44 2023 daemon.info hostapd: wlan0-1: STA b8:e6:0c:0e:8a:d9 IEEE 802.11: associated (aid 1)
Thu Jul 27 14:25:44 2023 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED b8:e6:0c:0e:8a:d9 0 0
Thu Jul 27 14:25:44 2023 daemon.info hostapd: wlan0-1: STA b8:e6:0c:0e:8a:d9 RADIUS: starting accounting session 70C67FCF05659A43
Thu Jul 27 14:25:44 2023 daemon.info hostapd: wlan0-1: STA b8:e6:0c:0e:8a:d9 WPA: pairwise key handshake completed (RSN)
Thu Jul 27 14:25:44 2023 daemon.info dnsmasq-dhcp[2169]: DHCPREQUEST(br-lan) 192.168.8.227 b8:e6:0c:0e:8a:d9
Thu Jul 27 14:25:44 2023 daemon.info dnsmasq-dhcp[2169]: DHCPACK(br-lan) 192.168.8.227 b8:e6:0c:0e:8a:d9 DK-MAC-MITH
Thu Jul 27 14:25:45 2023 daemon.err hostapd: 80/80+80 MHz: center segment 1 wrong or no second channel offset
Thu Jul 27 14:25:47 2023 kern.info kernel: [ 2668.518453] br-lan: port 4(wlan0-1) entered forwarding state
Thu Jul 27 14:25:48 2023 daemon.notice wpa_supplicant[2829]: wlan-sta0: Unknown event 62
Thu Jul 27 14:25:48 2023 daemon.err hostapd: 80/80+80 MHz: center segment 1 wrong or no second channel offset
What firmware version?
Hi, I’m using fw v 4.2.3 Release5
I’ll test and check it.
Any update on the testing?
This was happening to me on 4.2.x and still happening on 4.4.6.
