I just installed the new firmware on my gl-mt300n-v2, after setting the WiFi credentials again, my Tapo C200 cameras connected one time, when I set domain names for them I could not access them thu it (just with the ips)
I have reset the router to factory settings to prevent any error, but then the cameras just do not connect anymore.
I am using it on router mode and the wifi mode is b/g/n (although g/n also do not work.)
I can connect from my Mac and my Phone, but the cameras just do not connect.
If I try with an extender I have with the same SSID (disconnecting the mango) the cameras connect right away.
Is there something I can check to find the issue?
