Just bought and receive my units, so far the UI is so dumbed down is so similar like totolink units, I can’t even change the unit name. Sure doesn’t matter as long it works.
Questions.
How to set DHCP assign because I don’t see any menu to do that except in luci interface.
Why LAN IP limited to header with 192/172/10? I can change it (via LUCI again) but often the ip will just revert back to default after the unit is plugged off.
I read somewhere this version will have a bandwith monitor similar to gargoyle had, but so far the only thing I see is monitor based on text only.
Why some devices still listed in offline device even after the units has been rebooted?
Personally I bought this units to replace my old wr740 (with gargoyle) but almost everything is locked/limited idk if I made the right decision to purchase this unit.
