I have a MiFi that is broadcasting two SSIDs, one encrypted one guest. The encrypted SSID is bound to the LAN interface and issues DHCP on 10.1.1.0/25, while the guest SSID is bound to LAN2 interface issues DHCP on 10.1.1.128/25.
By default, an OpenVPN connection is made and tun0 serves as the default gateway. All of this works just fine on an array of devices - Windows PC, iOS, and Android. When they join the encrypted SSID, they get issued a DHCP address on the lower range. When they join the guest SSID, they get issued a DHCP address on the higher range. Regardless, all traffic is going out via tun0.
The last step is to add a route in /etc/rc.local to send the traffic from the guest subnet directly out wwan0 instead of through the VPN tunnel (tun0).
ip rule add from 10.1.1.128/25 table streamer
ip route add default via $WAN_GW table streamer
This setup works well on nearly every device except some Android devices (and not all). Win 10 laptop, iPhone, and some Android devices all can connect via DHCP to either SSID and get routed appropriately. However, when connecting to the guest SSID, some Android devices get stuck at “Obtaining IP address…” and loop through multiple attempts until finally arriving at a DHCP error.
What’s odd is, it seems to be the route for the guest network that causes the problem. When I remove the route, the troublesome Android devices connect just fine to the guest SSID, but of course everything on that SSID is still routing through tun0 instead of going out directly on wwan0. If I then re-add the route after the device has accepted its DHCP lease, all of its traffic is routed correctly.
Also interesting, is it’s only a problem with DHCP addressing. If I configure the Android devices to connect with a static IP and the route has already been added, they connect to the guest network just fine and are routed correctly.
Any idea what it could be about some of these Android phones and tablets that is not allowing DHCP addressing when my guest route is enabled??
/etc/config/network
config interface ‘loopback’
option ifname ‘lo’
option proto ‘static’
option ipaddr ‘127.0.0.1’
option netmask ‘255.0.0.0’config globals ‘globals’
option ula_prefix ‘fd5f:33fb:2b65::/48’config interface ‘lan’
option type ‘bridge’
option ifname ‘eth1’
option ip6assign ‘60’
option hostname ‘GL-MIFI-7d0’
option ipaddr ‘10.1.1.1’
option netmask ‘255.255.255.128’config interface ‘lan2’
option ifname ‘wlan2’
option ipaddr ‘10.1.1.129’
option netmask ‘255.255.255.128’config interface ‘wan’
option ifname ‘eth0’
option proto ‘dhcp’
option metric ‘10’
option peerdns ‘0’
option custom_dns ‘1’
option dns ‘8.8.8.8 8.8.4.4’config interface ‘wan6’
option proto ‘dhcpv6’config interface ‘tethering’
option proto ‘dhcp’
option metric ‘30’
option ifname ‘eth2’
option peerdns ‘0’
option dns ‘8.8.8.8 8.8.4.4’config interface ‘DROIDTETHER’
option proto ‘dhcp’
option ifname ‘usb0’
option metric ‘30’
option peerdns ‘0’
option dns ‘8.8.8.8 8.8.4.4’config interface ‘modem’
option ifname ‘wwan0’
option service ‘fdd-lte’
option apn ‘fast.t-mobile.com’
option proto ‘qmi’
option device ‘/dev/cdc-wdm0’
option metric ‘40’
option disabled ‘0’
option peerdns ‘0’
option dns ‘8.8.8.8 8.8.4.4’config interface ‘VPN_client’
option ifname ‘tun0’
option proto ‘none’
/etc/config/wireless
config wifi-device ‘radio0’
option type ‘mac80211’
option path ‘platform/ar933x_wmac’
option noscan ‘1’
option country ‘US’
option channel ‘11’
option txpower ‘10’
option hwmode ‘11g’config wifi-iface ‘default_radio0’
option device ‘radio0’
option network ‘lan’
option mode ‘ap’
option encryption ‘psk-mixed’
option wds ‘0’
option ifname ‘wlan0’
option ssid ‘encrypted’
option key ‘pass1’
option wmm ‘0’config wifi-iface
option mode ‘ap’
option wds ‘0’
option ssid ‘guest’
option key ‘pass2’
option wmm ‘0’
option encryption ‘none’
option network ‘lan2’
/etc/config/dhcp
config dnsmasq
option boguspriv ‘1’
option localise_queries ‘1’
option expandhosts ‘1’
option leasefile ‘/tmp/dhcp.leases’
option rebind_protection ‘0’
option local ‘/RVITclient.lan/’
option domain ‘RVITclient.lan’
option localservice ‘0’
option nonwildcard ‘0’
list server ‘8.8.8.8’
list server ‘8.8.4.4’
option noresolv ‘1’
option readethers ‘1’
option authoritative ‘1’config dhcp ‘lan’
option interface ‘lan’
option leasetime ‘12h’
option limit ‘50’
option start ‘1’config dhcp ‘wan’
option interface ‘wan’
option ignore ‘1’config odhcpd ‘odhcpd’
option maindhcp ‘0’
option leasefile ‘/tmp/hosts/odhcpd’
option leasetrigger ‘/usr/sbin/odhcpd-update’config domain ‘localhost’
option name ‘console.gl-inet.com’
option ip ‘10.1.1.1’config dhcp ‘lan2’
option interface ‘lan2’
option limit ‘50’
option start ‘1’
