DHCP option
Reporting an issue: i have a network with a Windows domain controller and DNS thus i had to add dhcp option 6 to the dhcp config file \etc\config\dhcp so that the windows server IP is leased as DNS by the DHCP
config dhcp ‘lan’
list dhcp_option ‘6,192.168.8.250’
I observed that the ip appears on the LAN->DHCP gateway option field of the web interface. That should be for option 3.
GL-AXT1800 fw 4.2.0
This text issue has been fixed in the new version. Thank you for your feedback.
