JohnD
January 1, 2025, 9:53am
On the GL-MT6000 (Flint2) I want to enable DHCP with Address Reservation on my guest network, but I don't want DHCP enabled on my main network.
For my main Network, I can go to:
NETWORK > LAN > Address Reservation (But only if the DHCP server is enabled)
If I go to:
NETWORK > Guest Network >
There is no Address Reservation, despite DHCP being enabled.
How can I enable address reservation on the guest network without enabling DHCP on my main network?
bruce
January 2, 2025, 1:16am
2
The clients joined in the guest Wi-Fi, you can find them and reserve IP on the Network > LAN > Address reservation. Even if disable the DHCP of the main (LAN) network.
Why do you disable the main DHCP and enable the guest DHCP?
What scenario?
Renato
January 2, 2025, 12:26pm
5
Just to inform that when we set the Static IP on LuCi, it appears with quotes and bracktes on "Address reseratvion" menu.
bruce
January 3, 2025, 7:49am
6
Noted, will submit to R&D team.
Renato
January 3, 2025, 8:00am
7
I forgot to say this is happening on 4.7.0-op24
bruce
April 17, 2025, 4:22am
8
This issue is fixed on v4.7.4 (or later) firmware.
system
Closed
October 14, 2025, 4:23am
9
