Yes, I ended up doing this
At first I set the ip on every machine and wanted to leave the LAN with no DHCP
So all LAN clients would need to set themselves the ip and Wifi clients receive ip
It's easier to set Address Reservations/Static IPs on the router than it is to go to each wired client and set the IP there, one by one... but what ever best works for you.
