Differences between MT300N-V2 test firm
Hi.
In the download page of test versions of this router there are several versions with the same date or with the same name.
Does anyone know what the differences are between them or where to find a changelog?
  • [openwrt-mt300n-v2-3.025-0729.bin11777KLast modified: Mon Jul 29 2019 11:16:32 GMT+0200 (hora de verano de Europa central)]
    (javascript:getObject(‘firmware/mt300n-v2/testing/openwrt-mt300n-v2-3.025-0729.bin’))
  • [openwrt-mt300n-v2-3.025-0805.bin11777KLast modified: Mon Aug 05 2019 09:49:38 GMT+0200 (hora de verano de Europa central)](javascript:getObject(‘firmware/mt300n-v2/testing/openwrt-mt300n-v2-3.025-0805.bin’))
  • [openwrt-mt300n-v2-3.026-0729.bin12033KLast modified: Mon Jul 29 2019 03:09:37 GMT+0200 (hora de verano de Europa central)](javascript:getObject(‘firmware/mt300n-v2/testing/openwrt-mt300n-v2-3.026-0729.bin’))
There is no changelog for testing firmware, so far only release firmware has changelog.
General rule is you want to be on the latest testing firmware if possible. You will get the latest features and also the latest fixes. When you ask for support on the forums we expect you to be on the latest version unless stated otherwise.
OK. But which one is the last?
the most recent dated August 8?
the highest version number v2-3.026?
3.026-0729 is the latest. v3.026 built on the 29th of July.
And now the official version is v3.025 of August 12?
And we continue without changelog.
I already tried v3.026 and solved some of the problems of previous versions, but it was impossible to operate Transmission.
It seems to me that GLinet has a serious problem with its way of handling the firms and its little information, in addition to eliminating the page of bugs, and the firms of the v2.xx (for now the only stable ones and with hardly any bugs) of the page of downloads.
v3 is still under testing for your router so there is no changelog.
GL only posts release logs.
The v3 is actually more stable than v2 because v2 had a bunch of other problems and random memory leaks.
If you need a copy of the v2 firmware anyway you can contact customer support at:
[email protected]
