I'm trying to get to the root of my internet disconnects on my flint 2 however unfortunately whenever the internet goes down the logs are spammed with adguard queries that have failed.
How can I adjust the log levels to not log anything from adguard home in syslog?
Banjer
October 16, 2025, 11:52am
3
Maybe disable Adguard for the time being while troubleshooting?
You can SSH into the router and use the following command to filter out ADG Home logs.
logread -f | grep -v AdGuardHome
I just stopped adguard from writing to syslog
root@GL-MT6000:~# cat /etc/init.d/adguardhome
#!/bin/sh /etc/rc.common
# shellcheck disable=SC2034
# shellcheck disable=SC3043
USE_PROCD=1
START=99
. /lib/functions/gl_util.sh
model=$(get_model)
start_service() {
[ "$(uci -q get adguardhome.config.enabled)" = "1" ] || exit 0
mkdir -p /etc/AdGuardHome
#b1300 dose not support mmap,need link the data to tmp fs
[ "$model" = "b1300" ] && {
rm -rf /etc/AdGuardHome/data 2>/dev/null
mkdir -p /tmp/AGH_data
ln -s /tmp/AGH_data /etc/AdGuardHome/data
/etc/init.d/firewall reload
procd_open_instance
procd_set_param respawn
procd_set_param group explicitvpn
# procd_set_param stderr 1
# procd_set_param command /usr/bin/AdGuardHome --glinet --no-check-update -c /etc/AdGuardHome/config.yaml -w /etc/AdGuardHome -l syslog
procd_close_instance
stop_service(){
because I want to continue using AdGuard Home even for the time being.
system
Closed
November 16, 2025, 9:13am
7
