Disable dhcp server and ping static ip
hi all i have a Glinet mt300n
I connect to the lan port a device with a static ip as 30.20.10.10 different to the lan ip of the glinet router
I would like ping the static device
it is possible?
secondly I would like disable dhcp server in the glinet
it is possible without disable the router mode?
many thanks in advance
