Disable / Enable LAN ports GL-AR750
Hi guys
I have a GL-AR750 with OpenWrt 22.03.4 r20123-38ccc47687.
This device is setup on Access Point Mode and is connected to my network via WAN.
I need be able to disable/enable via SSH the LAN ports when I need.
Just the LAN ports, the router need to be able still connected to the internet via WAN.
Anyone can help with this?
Thanks
You can just start and stop SSH as you like.
But I would recommend to just have it active all time, since it's not an problem. Just go public key auth instead of password.
Sorry, my sentence was incorrect.
I need disable the LAN ports and no the SSH.
I wish we could. Or if someone knows how. I think this would be great for security if you're only using WiFi repeater mode :love_you_gesture::+1:
Should be no problem at all, just run ifdown eth#
Is not working:
root@GL-AR750:~# ifconfig
br-lan Link encap:Ethernet HWaddr 94:83:C4:01:59:68
inet addr:192.168.3.108 Bcast:192.168.3.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:8805 errors:0 dropped:1883 overruns:0 frame:0
TX packets:4102 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:867961 (847.6 KiB) TX bytes:454876 (444.2 KiB)
eth0 Link encap:Ethernet HWaddr 94:83:C4:01:59:68
RX packets:9209 errors:0 dropped:185 overruns:0 frame:0
TX packets:4224 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1061202 (1.0 MiB) TX bytes:466464 (455.5 KiB)
Interrupt:4
eth1 Link encap:Ethernet HWaddr 94:83:C4:01:59:69
RX packets:692 errors:0 dropped:0 overruns:0 frame:0
TX packets:9289 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:90714 (88.5 KiB) TX bytes:1812371 (1.7 MiB)
Interrupt:5
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:56 errors:0 dropped:0 overruns:0 frame:0
TX packets:56 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6112 (5.9 KiB) TX bytes:6112 (5.9 KiB)
wlan0 Link encap:Ethernet HWaddr 94:83:C4:01:59:68
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:8364 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1015743 (991.9 KiB)
wlan1 Link encap:Ethernet HWaddr 94:83:C4:01:59:69
TX packets:8404 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1022753 (998.7 KiB)
root@GL-AR750:~# ifdown eth1
Interface eth1 not found
root@GL-AR750:~# ifdown eth0
Interface eth0 not found
try
ifdown lan
