Disable Login from WAN
Hi to all, I would like to disable the login from the Firewall access from WAN. I have enabled the Dyn DNS Service. Because I would like to use WAKE-ON-LAW on my PC, maybe this activated the login from the Firewall from WAN. Do I need disable the port in advance settings from the firewall. Thank you in advance for your help. Kind Regards, Elena
Login from WAN is disabled by default. If you did not enable it (see Security - GL.iNet Router Docs 4 ) it isn't enabled.
Wake-On-LAN does not work via Internet, btw.
