<p style=“margin-bottom: 0in;”>What would be the proper settings to change to disable the remote access via the ddns address? AR150 running 2.20. Thanks</p>
You also need to disable port 83 in firewall. You can find it in /etc/config/firewall
That doesn’t really answer the question.
disabling ddns just means the address is hidden. I don’t want the access available at all (port 83 should be closed). How do I turn that access off?
Thank you
you can remove port 83 from firewall, either by modifying /etc/config/firewall or set up in Luci.
