unfortunately I cannot disable roaming on my router.
I’m right now in Austria with my German SIM card. I have disables roaming but the internet is still working.
I have the latest beta firmware and I also tried:
Any ideas? Thank you!
Please check whether the configuration has been applied successfully?
AT+QNWPREFCFG="roam_pref"
Thanks!
I get it.I will check it.
Any News here yet? Would be great
Hi there,
same problem here. 100m from the boarder can’t disable roaming. Expensive; my ISP likes to charge me…
So, something going on in this direction?
Regards
any update on that issue would be great!
It only supports international roaming configuration.
Enable: AT+QNWCFG=“data_roaming” ,0
Disable: AT+QNWCFG=“data_roaming” ,1
Hello I have the same problem, I have an O2 Sim in Germany with EU roaming without Switzerland, can you deactivate certain countries (Switzerland), or me?
